Mass air flow sensor?? - TCCoA Forums
post #1 of 6 (permalink) Old 09-27-2006, 06:19 PM Thread Starter
Question Mass air flow sensor??
I was wanting to know if there is a particular reason that my '89 Bird doesn't have a MAF. My intake tube just goes from the filter to the throttle body. I have no idea why there isn't one. The car runs great and the engine and tranny are strong. Thanks for the info. MAC
PWINCORP is offline
post #2 of 6 (permalink) Old 09-27-2006, 06:45 PM
It's because it has a MAP sensor. Engine vacuum is used to measure the load on the engine instead of directly measuring the volume of incoming air. Just a different design is all.
post #3 of 6 (permalink) Old 09-27-2006, 06:46 PM
JMags's Avatar
IIRC it was '89 and early '90 cars that were speed density instead of Mass Air Flow. Your car uses known tables of engine efficiency to run.
JMags is offline
post #4 of 6 (permalink) Old 09-27-2006, 09:11 PM
Yep, 89-90 3.8L NA MN12's used a speed density (MAP sensor) setup.
89-90 3.8L SC MN12's, and all 91-97 MN12's used a MAF setup.
-Rod
post #5 of 6 (permalink) Old 09-30-2006, 01:38 AM
Pic
On firewall.
soop is offline
post #6 of 6 (permalink) Old 10-03-2006, 05:45 PM Thread Starter
Thanks for the helpful info. I'll post pics soon with my progress on rebuilding.
PWINCORP is offline
