question on old forum... - TCCoA Forums
post #1 of 14 (permalink) Old 07-15-2002, 12:18 AM Thread Starter
anomnity's Avatar
Question question on old forum...
ok..
someone asked me if i had the same car as them...
any volunteers?
anomnity is offline
post #2 of 14 (permalink) Old 07-16-2002, 08:43 AM
Exclamation It was me
Yeah that was me!!! I have a 90LX And was trying to help me locate the MAP
Willow9238 is offline
post #3 of 14 (permalink) Old 07-16-2002, 11:15 AM Thread Starter
anomnity's Avatar
did you ever find it?
it it right in the middle.
it has a vaccum line to it on the right which goes near the intake and a elec. connector on the left.
anomnity is offline
post #4 of 14 (permalink) Old 07-16-2002, 02:27 PM Thread Starter
anomnity's Avatar
anomnity is offline
post #5 of 14 (permalink) Old 07-16-2002, 05:08 PM
Thanks man, do u think this could the car to rev up so high
post #6 of 14 (permalink) Old 07-17-2002, 08:19 AM Thread Starter
anomnity's Avatar
i dunno, usually if thats bad the car runs liek a pile of shit.
i guess test the mapp by unplugging the connector for a few to see any difference, but i dont think that could be the problem...
your timing could be off too.
anomnity is offline
post #7 of 14 (permalink) Old 07-17-2002, 01:36 PM
Unhappy hmmmm
ok thanx, If my timing is off...Isn't that an internal engin problem
post #8 of 14 (permalink) Old 07-17-2002, 07:31 PM Thread Starter
anomnity's Avatar
no not really....its not absolutly impossible to do...but a timing helps alot...i can get carburated cars timing on pretty good with out the light..but EFI is different.
anomnity is offline
post #9 of 14 (permalink) Old 07-17-2002, 07:31 PM Thread Starter
anomnity's Avatar
sorry..timing light
anomnity is offline
post #10 of 14 (permalink) Old 07-26-2002, 10:48 AM
How do I use a timeing light. I never used one b4
post #11 of 14 (permalink) Old 07-27-2002, 12:00 AM Thread Starter
anomnity's Avatar
find #1 plug and hook the clamp or connect the connector the the wire...
then hook the light up to the battery to get power...
then look down by you harmonic balancer(the pulley underneath your water pump)..there should be a bar with numbers...
ok..now that you have located this....there is an electrical connecter on the dist....un-plug this...this disables the computer advancement...
then once you've done this start the car...and point the timing light down at the numebrs and you should see a mark on the balancers that flashes by some number...
im not sure what the number you have to set it to, but you have to turn the dist. to advance or retard the timing...make sure you dist can be turned before you try...
if you need more help i'll post pics...
Solid Black 1987 T-bird 5.0
anomnity is offline
post #12 of 14 (permalink) Old 07-27-2002, 12:58 AM
Exclamation Thanks
I think I need the pics I'm trying to figure out which one is th dist.
Thanks anomnity
one
Will
post #13 of 14 (permalink) Old 07-27-2002, 07:42 AM
Oh I feel like an idiot. A dist is the ditributer. Duh!!!! I had a brain fart, I'm sorry but thanks anyway.
Aight Then,
Will
One Love Hawaii
post #14 of 14 (permalink) Old 07-27-2002, 07:06 PM Thread Starter
anomnity's Avatar
ok...
here is the connector...
and the balancer,...the numbers for timing are on teh otehr side...you'll see them once you point the timing light down there...
and i still dont know...but i think its sippose to be set on 8...thats what mine is on at least..it has been awhile since i've timined anything.
and once you connect the connector back it should jump back to 15...
anomnity is offline
