1988 T-bird no start - TCCoA Forums
post #1 of 4 (permalink) Old 10-16-2006, 08:15 PM Thread Starter
I have a 1988 T-bird and it will not start. It gets gas because the plugs are wet but it gets no spark. I changed the ignition coil but it still doesnt start. what else should I look for? thanks
Dolomite is offline
post #2 of 4 (permalink) Old 10-16-2006, 08:46 PM
Could be the distributor or ignition module. You get no spark at all at the coil?
post #3 of 4 (permalink) Old 10-16-2006, 10:24 PM
gary95tb's Avatar
There is a TFI (Thick Film Ignition Module) That go bad on Ford vehicle's from the Eighties. My old 88 bird had one it was mounted in a heat sink in front of the Radiator. Gray in color most of the time. Replacement one sometimes are Black. Try to replace that. Link below with picture.
Others my be I the side of the Distributor
http://info.rockauto.com/Motorcraft/...html?DY533.jpg
Hope this helps
Gary
gary95tb is offline
post #4 of 4 (permalink) Old 10-18-2006, 10:46 AM
Is is a 2.3l? If it is, they have a problem with the distributor shaft moving too much and it doesnt send the right signal, therefore no start. My 88TC had the same problem every once in a while. She had about 187K on the motor. You could actually move the distributor side to side when you grabbed it.
