rough idle - TCCoA Forums
post #1 of 3 (permalink) Old 12-06-2002, 04:24 PM Thread Starter
rough idle
i have a rough idle at very low rpm, the car vibrates if i have my foot on the pedal very lightly, enough to only go 10 mph, but during normal driving its fine.. but once i take my foot off the pedal an the engine slows down, it vibrates again an then it stops vibrating once idle, whats wrong?
HiFi is offline
post #2 of 3 (permalink) Old 12-06-2002, 10:56 PM
Start with the basics
I would first check the basics: your spark plugs/wires, rotor, air filter, fuel filter, clean your MAF, and check your IAC. Also check and make sure you do not have any vacumn leaks. I could be wrong, but from what you have said it sounds a lot like your IAC, or even a vacumn leak.
Are there any check engine lights or codes thrown?
I am sure there are also other people here who have other ideas as well. Just my 2 cents! Good luck!
espicer is offline
post #3 of 3 (permalink) Old 12-08-2002, 01:44 PM
I just replaced my headgasket and it was still missing. only at idle so i went to Auto Zone and asked for a EEC test. The code was 121 i believe. Wich means TPS throttle positioning sensor. when the engine high miles it burns the contact at the most used throttle position. Highway milaged cars shake at highway speeds.
BigMerc is offline
