8.8 trac lock - TCCoA Forums
post #1 of 6 (permalink) Old 12-06-2002, 06:22 PM Thread Starter
Ashish's Avatar
Send a message via AIM to Ashish
8.8 trac lock
I was planning on getting a trac lock from a junkyard of a SC w/ half shafts. Is there anything else that I will be needing. will I need a new speedo gear? Also what year SC's would u guys recommend also any info which will make the mod easier will help.
1997 Birdie, its the good one. Limited Edition Sport Sold
9/6/03-9/7/03-J mod & Mark VIII TC 12/26/03-Apten Chip & 03 GT MAF 3/11/04-3/14/04-PI Cams & PI Intake 8/19/04-FRPP 3.73 Diffy2/26/05-SCT chip (burned by Ken B.)
1998 Z28 M6 5.7 LS1
Ashish is offline
post #2 of 6 (permalink) Old 12-06-2002, 07:48 PM
jim
you should seriously consider swapping in 3:73's or 4:10's...and do a rebuild if necessary...8.8 should bolt right in
jim is offline
post #3 of 6 (permalink) Old 12-06-2002, 07:53 PM Thread Starter
Ashish's Avatar
I am going to try to find one with 3.73. Will there be some kind of tag that will tell me what kind of gears the pumpkin has, I know there is the door tag, is there a tag on the pumpkin itself, and do I have to change the speedo gear.
1998 Z28 M6 5.7 LS1
Ashish is offline
post #4 of 6 (permalink) Old 12-06-2002, 08:32 PM
jim
there should be a tag on the diff...but your not gonna find a stock irs diff with 3.73's
jim is offline
post #5 of 6 (permalink) Old 12-06-2002, 08:35 PM Thread Starter
Ashish's Avatar
alright thanks
1998 Z28 M6 5.7 LS1
Ashish is offline
post #6 of 6 (permalink) Old 12-08-2002, 09:27 AM
Get a pumpkin out of an automatic, it'll have 3.27 gears. Look on the tag & it should have 3 L 27 on the bottom row of characters.
If you want a steeper gear, you can get a 3.55 out of a 87/88 5spd Turbo Coupe or a 3.73 from the auto version. You can then install the ring/pinion/carrier in your IRS housing.
'bird
tbird88 is offline
