Water POURING out tail pipe - TCCoA Forums
post #1 of 11 (permalink) Old 10-22-2006, 12:39 PM Thread Starter
What happened?!?!
Water totally drains out of the radiator and ends up coming out the tailpipe...
Head gasket? Intake manifold?!?!
Help!!
3.8L
Let me know what you guys think...TIA
Dave
fjazzbass is offline
post #2 of 11 (permalink) Old 10-22-2006, 01:51 PM
Whining Intakes Rock
Al_Florida's Avatar
Head gasket would be my first thought.
# 0 rows returned
# drop table users;_
Al_Florida is offline
post #3 of 11 (permalink) Old 10-22-2006, 02:21 PM
dwinthrup's Avatar
yea or cracked head
dwinthrup is offline
post #4 of 11 (permalink) Old 10-22-2006, 04:20 PM
Or both. Most likely head gasket though. Either way the heads have to come off and get checked out by a machine shop.
Mike
post #5 of 11 (permalink) Old 10-22-2006, 06:34 PM
With the 3.8 head gaskets are the obvious fist choice answer but until you pull the heads you won't know if it only needs a head job or what...
Southpaw is offline
post #6 of 11 (permalink) Old 10-22-2006, 06:35 PM
mybird_91's Avatar
Send a message via Yahoo to mybird_91
yes head gaskets.....i had the same problem, coolant pouring out of dr. side pipe (true duals)........ but both sides head gaskets were toast........get your heads resurfaced, don't just replace gaskets, and also replace the head bolts.
1994 Chevrolet Camaro Z28
LT1 350
K&N Intake and Flowmaster Exhaust
1995 Lincoln Mark VIII
hollow front cats, 3rd cat still there, no resonator, replaced by a single 40 series flowmaster, 2 3"x18" tips out back. screamin demon coil packs, mallory pro wires, motorcraft platinum plugs. intake resonator delete.
mybird_91 is offline
post #7 of 11 (permalink) Old 10-22-2006, 09:33 PM
Yea hears a new memeber of the head gasket club
Destructor90 is offline
post #8 of 11 (permalink) Old 10-22-2006, 10:01 PM
ECU_Q's Avatar
Send a message via AIM to ECU_Q
I wonder how many of us there really are.
ECU_Q is offline
post #9 of 11 (permalink) Old 10-22-2006, 10:40 PM
The Stevinator's Avatar
my guess would be it was so bad it cracked the head(s). most of the time the water burns off giving the white smoke effect, not spewing out the tailpipe.
The Stevinator is offline
post #10 of 11 (permalink) Old 10-22-2006, 11:20 PM
mybird_91's Avatar
i had all the above (shooting coolant and white smoke) no cracks in heads but i put the brand new heads on (less than 5,000 from the previous motor, motor had lower end problems and the owners before replaced the whole upper half). got lucky on that
LT1 350
post #11 of 11 (permalink) Old 10-23-2006, 06:38 AM
I wonder how many aren't?
Southpaw is offline
