engine light - TCCoA Forums
post #1 of 11 (permalink) Old 10-26-2006, 07:35 PM Thread Starter
engine light
Just a quick question about an engine light on a 89 bird 3.8 N/A. While taking my car down to get it inspected, the engine light came on. When I turned the car off at the gas station and restarted it, the engine light was no longer on. It did come backon after a few miles which is leading me to believe it's the O2 sensor(s). What do you guys think? Also, is there any way to check the light? Would a bad O2 cause the car to idle a little rough and run rich? I believe it would since I don't havea MAF and O2's are an input. Thanks
PWINCORP is offline
post #2 of 11 (permalink) Old 10-27-2006, 11:32 AM
white lincoln's Avatar
Go to an autoparts store and have them read the codes. That should tell you what you need to do.
white lincoln is offline
post #3 of 11 (permalink) Old 10-27-2006, 11:46 AM
Autopart stores generally don't read OBDI systems.
post #4 of 11 (permalink) Old 10-27-2006, 01:30 PM
mybird_91's Avatar
Send a message via Yahoo to mybird_91
its not a bird if the light ain't on........i failed my emissions test.......so i replaced my o2 sensors and passed
1994 Chevrolet Camaro Z28
LT1 350
K&N Intake and Flowmaster Exhaust
1995 Lincoln Mark VIII
hollow front cats, 3rd cat still there, no resonator, replaced by a single 40 series flowmaster, 2 3"x18" tips out back. screamin demon coil packs, mallory pro wires, motorcraft platinum plugs. intake resonator delete.
mybird_91 is offline
post #5 of 11 (permalink) Old 10-28-2006, 02:49 AM Thread Starter
I know that auto stores won't read the codes. Just thought I'd ask in case someone else had this problem. I haven't done emissions yet, because I know it will fail. That is one headache I don't want to deal with yet. Luckily, they only check the tail pipe because of the year. Anything 94 and newer, they hook up to the computer and check for codes.
PWINCORP is offline
post #6 of 11 (permalink) Old 10-28-2006, 10:20 AM
Street Freekz
96_Cougar's Avatar
Send a message via MSN to 96_Cougar Send a message via Yahoo to 96_Cougar
Or a Cat for that matter. lol
My O2 sensor made my 'check engine' light come on a few times & I always had mine read by my mechanic.
My Cat had the "rich fuel" reading a few weeks before my 02 sensor went bad. After it went bad then it started to idle rough....hope that helps you out.
In Memory of FD 420
"This will remain the land of the free only so long as it is the home of the brave" ~ Elmer Davis, American news commentator (1890-1958). God bless all veterans: past & present.
96_Cougar is offline
post #7 of 11 (permalink) Old 10-29-2006, 01:47 AM Thread Starter
PWINCORP is offline
post #8 of 11 (permalink) Old 10-29-2006, 01:39 PM
Street Freekz
96_Cougar's Avatar
Originally Posted by PWINCORP
Welcome
In Memory of FD 420
post #9 of 11 (permalink) Old 10-29-2006, 07:34 PM
I went to Canadian tire and bought a code reader for my 94' N/A bird for $50.00. Worked well helped me troubleshoot alot.
foobarbigtime is offline
post #10 of 11 (permalink) Old 11-01-2006, 05:30 PM
blkadder's Avatar
Has anyone found a decent (read cheap) ODB1 code reader for the pre-ODBII MN-12's? I am sure someone has. I was curious of brand and model number. I am kind of tired paying my local guy to read the codes for me. My local parts stores tell me they can't help with the codes since the car is "ancient". Here I thought my 65 MG was old, and I find out my 94 Merc is ancient.
Thanks for any info guys.
Ron
...Semper Fidelis...
blkadder is offline
post #11 of 11 (permalink) Old 11-01-2006, 08:10 PM
The Stevinator's Avatar
actron makes a cheap one. part number cp9015. my only complaint is that while doing the engine on test, it's hard to hear the code readers beeping (it beeps the codes at you, and flashes a light). cheap but works.
The Stevinator is offline
