Fuel pressure gauge - TCCoA Forums
post #1 of 3 (permalink) Old 11-08-2006, 10:20 AM Thread Starter
Birdman232's Avatar
Fuel pressure gauge
I'm in the middle of putting a fuel pressure gauge in my car, and i'm not real sure where to mount the sender for the manual fuel pressure gauge. Nor the correct size fittings I need to use. I have an autometer ultralite manual fuel pressue gauge...if that helps for te size of the fittings/ braided SS hose I need to use.
Birdman232 is offline
post #2 of 3 (permalink) Old 11-08-2006, 11:41 AM
The most common place would be in place of the schrader valve on the fuel rail. There are adapters that will screw in place of the schrader valve and change it to the most common fitting.
post #3 of 3 (permalink) Old 11-08-2006, 08:05 PM
blkadder's Avatar
Just make sure you use the isolator mounted in the engine bay. Nothing will ruin your day faster than an EFI powered fuel leak in the passenger compartment.
Ron
...Semper Fidelis...
blkadder is offline
