help - TCCoA Forums
post #1 of 3 (permalink) Old 11-15-2006, 02:48 AM Thread Starter
help
ok guys kinda new here .i have a 93 thunderbird lx 3.8 a few questions.thi is my first 3.8 ive ever owned and ive heard their bad for blowing head gaskets,correct?well was wondering what some of the symptoms of a blown head gasket would be.also if i was to do an engine swap (same size) should i look for one the same year or are they changeable through the year models .
tbird1993 is offline
post #2 of 3 (permalink) Old 11-15-2006, 06:57 AM
This is a cars for sale forum. You should post this in the 3.8 forum.
post #3 of 3 (permalink) Old 11-17-2006, 03:38 AM
Blindloser1080's Avatar
You'll definately know when you have a blown HG. You'll have a white smoke comin out of the exhaust, a sweet smell, and your car will run like crap, because you will have a mis-fire. IF you take care of your car you should be fine. Yes, the 3.8s are notorious for the HG's, I even blew mine on my 96' but honestly, it was the best thing to ever happen to my car PERIOD.
I say that because I learned so much about my vehicle, and did about 99.8% of all the work by myself, with barely any mechanicing experience at all. Don't be scared about blowing your HG's, it's an experience that most of us go through with these engines. If you were to do any changing at all, I'd look for a set of 96+ heads for the 3.8, because they (supposedly) have fixed the HG problem with them, or atleast cured most of it. But double check with some other guys on this site before takin my word.
Blindloser1080 is offline
