3.8L fuel injector question - TCCoA Forums
post #1 of 11 (permalink) Old 11-16-2006, 06:43 AM Thread Starter
Does anyone know - are the fuel injectors in the 3.8L the same as the 5.0L injectors? if not, do you know the # rating on the 3.8 injector? Working on putting head gaskets on mine, and twisted one up last night (#&$%#%!!!) so its gotta be replaced. This is my first 3.8L, but I have a TON of 5.0 parts including injectors lying around!
Thanks everyone!
xldavidson is offline
post #2 of 11 (permalink) Old 11-16-2006, 09:43 AM
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
3.8 - 14 lb/hr
5.0 - 19 lb/hr
you cant use 5.0 injectors with a 3.8 injector harness.
2014 GT
1990 300ZX TT
big mike is offline
post #3 of 11 (permalink) Old 11-16-2006, 11:01 AM
4.3Lcougar's Avatar
i have some 3.8L mustang injectors you can have for $20+ shipping.. its from a 99+ mustang. i dont dont know it will work or don't!
1985 THUNDERBIRD CFI 5.0L..
4.3Lcougar is offline
post #4 of 11 (permalink) Old 11-16-2006, 12:01 PM Thread Starter
What color are the Mustang injectors? how much do you need total to ship them to zip 48124 (Dearborn, MI). Is that price for the set of 6?
post #5 of 11 (permalink) Old 11-16-2006, 01:53 PM
99+ Mustangs had the splitport engine which I believe has 19# injectors, but I may be wrong. I have a set of 6 almost brand new ones if you want. Let me know if interested.
post #6 of 11 (permalink) Old 11-16-2006, 02:04 PM Thread Starter
What color are they and how much shipped?
post #7 of 11 (permalink) Old 11-17-2006, 03:35 AM
Blindloser1080's Avatar
I'd honestly get the stock ones, unless you're making a crazy amount of HP to be able to use the extra FI. I just kept the stock ones, and they are working fine for me. But also, I believe if you change the injectors to 19 lb ones, you have to have a chip for the computer, to get the mixture correctly set up for 19 lbs instead of the stock ones.
Blindloser1080 is offline
post #8 of 11 (permalink) Old 11-17-2006, 07:46 AM Thread Starter
Well, Right now Im just trying to put the car back on the road. Stock is just fine by me, all I need is one injector and Im good to go. I dont know how long Im going to keep it, so putting crazy money into it is not smart right now. so as soon as I can find a stock injector, or set if the price is right, Im good to go!
post #9 of 11 (permalink) Old 11-18-2006, 05:50 PM
Ainline41's Avatar
Send a message via AIM to Ainline41
on a slightly similar topic, anyone know where i can find 24# injectors that are compatible with the 3.8 for a fairly reasonable price?
Ainline41 is offline
post #10 of 11 (permalink) Old 11-21-2006, 08:42 PM
3.8L, 5.0L, and 4.9L all use 14# injectors up to 1996
5.0L H.O. use 19# injectors (Mustang, 91-93 Tbird, and Mark VII LSC's)
rancherlee is offline
post #11 of 11 (permalink) Old 11-21-2006, 11:53 PM
Ainline41's Avatar
i know that, im looking to upgrade, and ive heard that some dont plug into the harness?? the same. if i found some 24# for a 5.0 would that fit in the 3.8?
