Motor mounts for 3.8L - TCCoA Forums
post #1 of 6 (permalink) Old 11-18-2006, 11:03 PM Thread Starter
Does anyone know who makes a solid motor mount for a 94 Thunderbird with a 3.8L engine?
Or does anyone make a stronger piece that can replace the factory mount? Thanks.
freeloader is offline
post #2 of 6 (permalink) Old 11-18-2006, 11:35 PM
Resident Line Creator
th3subtl3on3's Avatar
www.supercoupeperformance.com
-Brian
th3subtl3on3 is offline
post #3 of 6 (permalink) Old 11-19-2006, 12:35 AM
SplitPortBird's Avatar
I know my Autozone and AdvanceAuto Parts both sell ANCHOR mounts.. they offer the fluid filled (stock) or the solid units.
SplitPortBird is offline
post #4 of 6 (permalink) Old 11-21-2006, 09:52 AM
white lincoln's Avatar
white lincoln is offline
post #5 of 6 (permalink) Old 11-22-2006, 09:43 PM
The Stevinator's Avatar
either bill at supercoupe performance, or victor at spinning wheels sc sells them. i got them from victor, cheaper price. they're the same mount. they got them when mn12 went out of business. my best advice is GO SOLID RUBBER. it was scary when i got my old liquid filled rubber ones off.....in 4 pieces.
The Stevinator is offline
post #6 of 6 (permalink) Old 12-02-2006, 06:39 PM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
the solid rubber ones are nice. Much improvement over the stock hydraulic mounts. I have a prototype solid aluminum mount set with poly bushings in mine. You cant even make the motor move from its spot. They are stiff. Lots of vibration in the chassis because of it. But thats okay, its a weekend car. For some reason the guy who I tested them for never produced them. I dont know why.
-Thomas
Thomas is offline
