help please - TCCoA Forums
post #1 of 8 (permalink) Old 11-23-2006, 06:53 PM Thread Starter
help please
ok here is what is happening, i own a 1990 cougar ls 3.8L and just recently the oil pressure has been dropping really low when im at a stop adn it has oil in it. adn now it is dropping low when im going under 30mph. i also just recently noticed a loud knocking noise coming from the drivers side valve cover. it knocks at idle adn when im drivign adn gets louder upon high rpms. does anyone have any ideas on what this problem could be?
brs90cougar is offline
post #2 of 8 (permalink) Old 11-25-2006, 09:50 AM Thread Starter
does anyone know waht my problem could be any advice would be greatly appreciated
post #3 of 8 (permalink) Old 11-25-2006, 10:48 AM
Sounds like your engine or oil pump is worn out. Does it do it cold or only once heated up?
birds4us is offline
post #4 of 8 (permalink) Old 11-25-2006, 12:02 PM Thread Starter
it does it all the time now. it does it when it is warm adn when it is cold. it sounds more of like a clacking noise also. and it sounds like its coming from the driver side valve cover
post #5 of 8 (permalink) Old 11-25-2006, 01:29 PM
You could try a new oil pump, but I suspect that without actually measuring oil pressure that it may be time for a new engine.
birds4us is offline
post #6 of 8 (permalink) Old 11-25-2006, 07:10 PM
blkadder's Avatar
I would hook up a manual oil pressure gauge in place of the stock sender. It may be that you have a bad sender, and a bad lifter making all the noise. Always try the easy stuff before you go pulling the bottom end.
Ron
...Semper Fidelis...
blkadder is offline
post #7 of 8 (permalink) Old 11-25-2006, 10:38 PM
Kelsey Smith's Avatar
Send a message via MSN to Kelsey Smith
Sounds to me like the lower end is wearing out. How many miles are on it?
"WHAT CONE?!?!
1997 T-Bird Sport, 'Interceptor' (12 ESP 2008-2012)- CAI, 2.25 duals, Flowmaster 40 series, Clear corners, BBK 70mm Throttle Body, TrickFlow upper intake, PI Intake, BBK adjustable fuel pressure regulator, LE stripes, Bullitt-style gauge faces. 18x9 wheels, Sniper tuned, 3,620 pounds
1991 Ford F250 - Air restrictor delete. Cat delete.
1991 T-Bird 'Interceptor II' (12 CP 2013-) - Race-prep, Full custom "interior", Carb'd 302, Trick Flow twisted wedge heads, stage 1 cam, Custom Koni coil-overs front, Koni yellows rear, Cobra front brakes, fuel cell, 18X9 wheels, 275/30 Hoosier A6, 4.11 T-Lok. 3000 pounds
2004 Toyota Solara SE - V6, Sport package, Muffler delete, 17X7 wheels, 235/50 Conti ExtremeContact DWS
Kelsey Smith is offline
post #8 of 8 (permalink) Old 11-28-2006, 11:25 AM Thread Starter
it has 135000 miles on it
