PVC valve and hose question. - TCCoA Forums
post #1 of 4 (permalink) Old 11-27-2006, 05:26 PM Thread Starter
I just got my PVC changed on my 91 NA 3.8 and I looked at it and there are two pipes coming off of it. one bigger on closer to the bottom that splits off and then a smaller one that comes out the side of the top. there is nothing hooked up to the smaller one at the top!!! Whats is that for??
MN12BIRD is offline
post #2 of 4 (permalink) Old 11-27-2006, 05:32 PM
It is for a diferent vehicle that uses both outlets. Make sure that the top outlet is closed or capped off.
birds4us is offline
post #3 of 4 (permalink) Old 11-27-2006, 05:35 PM Thread Starter
oh it looks open but I'll check again just to make sure. Thx!
MN12BIRD is offline
post #4 of 4 (permalink) Old 11-27-2006, 06:40 PM
The unused port should have a little plastic plug stuffed in it to block it off.
Usually the plug is molded onto the plastic part of the PCV and you just twist it off and stick it on the port you didn't use.
Southpaw is offline
