Please Help!!!! - TCCoA Forums
post #1 of 6 (permalink) Old 12-03-2006, 09:32 PM Thread Starter
Please Help!!!!
PLEASE HELP ME i HAVE A 97 XR7 3.8 AND MY A/C CLUTCH WENT OUT,SO I NEED A NEW BELT MINUS THE A/C BUT CANT FIND ONE ANYWHERE?ANY SUGGESTIONS?
DESTINYXR7 is offline
post #2 of 6 (permalink) Old 12-03-2006, 11:30 PM
Nativedetroiter's Avatar
so you would like to do an A/C Delete? You can get another compressor, and install that without a problem...
Nativedetroiter is offline
post #3 of 6 (permalink) Old 12-04-2006, 02:52 AM
Blindloser1080's Avatar
Or you should be able just to replace the A/C clutch, I know that Autozone carries them, maybe check there if you got one locally.
Blindloser1080 is offline
post #4 of 6 (permalink) Old 12-04-2006, 04:13 AM
Pedal Faster
Josh_Keady's Avatar
If it's not completely seized (that is, the pulley will just freewheel when the compressor isn't engaged) you could just unplug the compressor.
Josh Keady
Josh_Keady is offline
post #5 of 6 (permalink) Old 12-04-2006, 06:46 PM
blkadder's Avatar
There will not be a listing in any parts stores for a belt that bypasses the AC. The best way (six years working in a parts store), remove the old belt, and run a string around the pulleys in a configuration that is going to work, and turn all the stuff in the right direction. Measure the string, and let the parts store that you need a six groove belt X number of inches long.
That should get you the right length belt, but I would imagine that there will be some difficulty running it properly.
Ron
...Semper Fidelis...
blkadder is offline
post #6 of 6 (permalink) Old 12-04-2006, 08:36 PM
95xbird's Avatar
Have you tried to jump the compressor to see if it is siezed???Should be a low pressure cut off switch. You can jump with a paper clip.
Its slow, Really.
LS1 KILLER
1995 svo Tbird. R.I.P.
95xbird is offline
