bad o2's? - TCCoA Forums
post #1 of 14 (permalink) Old 12-05-2006, 08:19 AM Thread Starter
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
bad o2's?
i am getting a check engine light that comes on a few minutes after firing it up, but before reaching full operating temperature, then it goes away. it also comes on while traveling 75-80 mph and stays on until i slow down to about 70. my gas mileage seems a bit weak, too. finding an obd1 code reader around here to borrow is a chore, and i need a quick diagnosis. does this sound like bad o2 sensors?
2014 GT
1990 300ZX TT
big mike is offline
post #2 of 14 (permalink) Old 12-05-2006, 09:25 AM
Awaiting E-Mail Confirmation
tinman_72's Avatar
I am not sure about your diagnosis, but do you know about grounding one of the pins on the OBDI port and counting the flashes? I did it to my '93 Ranger and it was a pain in the butt but it does work and you don't need a reader.
tinman_72 is offline
post #3 of 14 (permalink) Old 12-05-2006, 09:33 AM Thread Starter
Motorboatin' SOB
big mike's Avatar
yeah, i heard of that trick and i got a thread going about that. not much help so far cuz i need a pic.
2014 GT
1990 300ZX TT
big mike is offline
post #4 of 14 (permalink) Old 12-05-2006, 10:08 AM
there ya go
Blue LS is offline
post #5 of 14 (permalink) Old 12-05-2006, 10:25 AM Thread Starter
Motorboatin' SOB
big mike's Avatar
what are you using to connect the pins?
2014 GT
1990 300ZX TT
big mike is offline
post #6 of 14 (permalink) Old 12-05-2006, 10:27 AM
In the pic its just a piece of red plastic so it would show up better. When I ran the test I used a paper clip, works great.
Blue LS is offline
post #7 of 14 (permalink) Old 12-05-2006, 10:32 AM
Baby Huey
warmaster259's Avatar
I have to do pretty much the same thing on my 88 cutlass, except that both pins are in the same harness.
Jim
warmaster259 is offline
post #8 of 14 (permalink) Old 12-05-2006, 10:32 AM
Sig Nazi & Gallery Moderator
mrs.tbirdbrain's Avatar
Our '93, when stock, did the same thing when doing highway trips - it would go on and off with no apparent reason.
If you are good at wiring, you could get these:
http://cgi.ebay.com/ebaymotors/NEW-M...mZ160030691132
We bought from this place for sensors for our Exploder....works just fine.
TBIRDBRAIN - PRESTON
YOU WILL NEVER BE FORGOTTEN
4/22/63 - 4/23/14
RIP JOEL BENDER
07/30/1979 - 03/26/2006
mrs.tbirdbrain is offline
post #9 of 14 (permalink) Old 12-05-2006, 07:30 PM
bowez's Avatar
Does it drive better cold or after warm up, does it bog under WOT? Though intially it does sound like O2.
To pull EEC-IV codes jumper the top right plug of the larger connector with the small connector.
93 SC Tbird
96 1/2 XR7 Sold and Salvaged
93 5.0 Tbird
bowez is offline
post #10 of 14 (permalink) Old 12-08-2006, 11:57 AM
Any luck with the codes Mike?
Blue LS is offline
post #11 of 14 (permalink) Old 12-08-2006, 12:08 PM Thread Starter
Motorboatin' SOB
big mike's Avatar
i cant tell a difference whether its cold or warmed up. no bogging under full throttle.
i havent pulled codes yet.
2014 GT
1990 300ZX TT
big mike is offline
post #12 of 14 (permalink) Old 12-08-2006, 05:35 PM
bowez's Avatar
Mike, either pull the codes or get a volt meter on the O2. Only other thing else I could come up with is MAF, but I lean toward O2. If so hurry up and change them and stop getting my headers dirty.
93 SC Tbird
93 5.0 Tbird
bowez is offline
post #13 of 14 (permalink) Old 12-08-2006, 05:39 PM
Sounds exactly like what my truck was doing. Changed the 02 today and all is well
Blue LS is offline
post #14 of 14 (permalink) Old 12-19-2006, 08:47 AM Thread Starter
Motorboatin' SOB
big mike's Avatar
dont tell me that. i sold them along with my entire exhaust
yeah, late reply. sue me
2014 GT
1990 300ZX TT
big mike is offline
