How to Replace Spark Plugs? - TCCoA Forums
post #1 of 17 (permalink) Old 12-06-2006, 06:35 PM Thread Starter
Stroked and Blown
BlakTbird96's Avatar
I can't find a "How to" for replacing spark plugs. The tech article only stated which ones to use and where to gap them at. Can someone explain how to do this in basic, simple english. What tools will I need, how do I do it?
I originally wanted to replace them on the Contour, but because I don't drive the Thunderbird much, and because there's more room under the Tbirds hood, I have decided to use it as my gerbil. Once I become more inclined, I will try to replace them on the Contour. I think the Contour will be more complicated to do.
Thanks.
My other home:
Mid-AtlanticMN12's
'96 Ford Tbird 3.8 SC
BlakTbird96 is offline
post #2 of 17 (permalink) Old 12-06-2006, 06:43 PM
For a 3.8 tbird, you will need a 5/8" spark plug socket, a ratchet, swivel, and some extensions, and a flat head screwdriver. First loosen the hose clamps on the ends of the intake tube and remove the tube. Now follow the spark plug wires to the plugs. Only do one plug at a time so you won't accidently cross wires. To get the boot off the plug, reach down and grab it, then twist and pull until it comes off. Once the boot is off, use the socket and ratchet (and swivel/extension if needed) and remove the plug. Take the new plug and put a little anti-sieze on the threads then reach down and start threading it in, and tighten with the ratchet and socket. Repeat this procedure for all the plugs doing one at a time and you will be fine. The hardest part is figuring out how your arm has to contort to get down to the plug.
MadMikeyL is online now
post #3 of 17 (permalink) Old 12-06-2006, 07:00 PM
Street Freekz
96_Cougar's Avatar
Send a message via MSN to 96_Cougar Send a message via Yahoo to 96_Cougar
^^ What he said. ^^
Have fun . It can be a pain in the a$$ at times...
In Memory of FD 420
"This will remain the land of the free only so long as it is the home of the brave" ~ Elmer Davis, American news commentator (1890-1958). God bless all veterans: past & present.
96_Cougar is offline
post #4 of 17 (permalink) Old 12-06-2006, 07:03 PM
I recommend doing the passenger-side plugs first so that you get the hard ones out of the way. That way when you get to the driver's side, you'll be so happy at the simplicity of it.
post #5 of 17 (permalink) Old 12-06-2006, 07:23 PM Thread Starter
Stroked and Blown
Is it that bad? To change them on my Contour, I need to remove all 6 of the wires and the entire coil pack just to get to the back 3! Is the Thunderbird the same way? Now, I'm wandering if I should just pay a service shop to do it instead.
My other home:
Mid-AtlanticMN12's
post #6 of 17 (permalink) Old 12-06-2006, 07:26 PM
You don't have to remove anything except for the intake tube. After that it's just maninpulating your tools and hands to get them in/out right. Like I said, the passenger side is a *****, but the driver side can be done in two minutes. I've got it down to about 7 minutes for all 6 spark plugs.
Don't pay the shop, you can do it.
post #7 of 17 (permalink) Old 12-06-2006, 07:32 PM Thread Starter
Stroked and Blown
What are the best plugs to use? What about those double platinum things?
Also, what is the flat head screwdriver for, I didn't see it mentioned in the steps.
My other home:
Mid-AtlanticMN12's
post #8 of 17 (permalink) Old 12-06-2006, 07:35 PM
Douple plats are the OE plug. They give long life and good fuel economy. I use them but other people have their preferences. Just go with Autolites.
post #9 of 17 (permalink) Old 12-06-2006, 08:04 PM
Flat head screwdriver is to loosen the hose clamps on the intake tube and to pry the tube off the throttle body and MAF.
post #10 of 17 (permalink) Old 12-07-2006, 01:51 AM
Pedal Faster
Josh_Keady's Avatar
A lot of people (and this has nothing to do with master486's post) are quick to say, "Wow, I changed to platinum plugs and got a huge performance and driveability increase!" Well, I'm going to go out on a limb and say that the increase wasn't due to the platinum/very expensive new spark plugs, it was probably simply because the old plugs were crap, and you'd have seen the same results with cheapo copper plugs, simply because they are better than what was in there.
I would not waste the extra money on platinum plugs for a 3.8 Bird. My 2 cents.
Josh Keady
Josh_Keady is offline
post #11 of 17 (permalink) Old 12-07-2006, 08:45 AM
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
autolite 2545 coppers, found at walmart, are the best deal. let the engine cool down for a few hours first.
2014 GT
1990 300ZX TT
big mike is offline
post #12 of 17 (permalink) Old 12-07-2006, 10:11 AM
Traveler's Avatar
Originally Posted by big mike
.......let the engine cool down for a few hours first.
lol Most practical advice I've seen yet! Can't tel you how many times I've burnt my hands cause I just had to get it done NOW!
Also it is a good idea to get the passenger side done first. Don't ask why, just is.
The Bird will actually be easier than the Contour because it doesn't have a "back bank" just a Left and right. I've tried to do plug changes on east/west V-engines before. It sucks trying to reach those back plugs.
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #13 of 17 (permalink) Old 12-07-2006, 03:05 PM
It is nice
not that great advice but... use a piece of rubber hose to pull the spark plug out of the hole (once loosened). It is easier then messin with a spark plug socket that has the rubber piece already in it because they always move around, fall out, etc. You can start threading the plug with the rubber hose too... yippiiiiiiiiiiieeeeeeeee.
91CougarLS is offline
post #14 of 17 (permalink) Old 12-07-2006, 03:43 PM
Traveler's Avatar
You're wrong, I think thats great advice. I'll have to try that next time. Might save my poor old hands from damage to.
Low Miles
Wifes Car
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #15 of 17 (permalink) Old 12-07-2006, 06:50 PM
It is nice
lmao... thx
post #16 of 17 (permalink) Old 12-08-2006, 01:22 AM
Lucky you don't have a XR7 or SC.
Darren is offline
post #17 of 17 (permalink) Old 12-09-2006, 06:41 AM
I recommend sticking with motorcraft. Same with the wires. Aftermarket stuff is junk.
foobarbigtime is offline
