things i can do to a 3.8 for power on a budget - TCCoA Forums
post #1 of 5 (permalink) Old 12-09-2006, 11:46 PM Thread Starter
Talking things i can do to a 3.8 for power on a budget
ok i want to buikd a motor for my bird i have a 96 3.8l and i want to stay in a budget of 2000-2500 i will do all the work my self i can bore hone and basically anything else i need i am currently in college getting my A.S. in auto technology
i have acces to lifts and all the the tools i need
i would tlike to build the bottom and top end
in the future i plan on supercharging
does anyone know of any links i can goto to finds parts for my engine or will all the internals for a mustange 3.8 fit?
thanks for all the help in advance
fast86rx-7 is offline
post #2 of 5 (permalink) Old 12-10-2006, 12:04 AM
Kelsey Smith's Avatar
Send a message via MSN to Kelsey Smith
If you plan on supercharging, I would reccomend getting a Supercoupe bottom end. I'm not sure just how much stronger the SC block is, but they are supposed to be stronger than the N/A versions. Or, go look around http://www.supersixmotorsports.com/, they've got all kind of V6 parts. Best of luck with your 3.8, and welcome to the TCCoA
"WHAT CONE?!?!
1997 T-Bird Sport, 'Interceptor' (12 ESP 2008-2012)- CAI, 2.25 duals, Flowmaster 40 series, Clear corners, BBK 70mm Throttle Body, TrickFlow upper intake, PI Intake, BBK adjustable fuel pressure regulator, LE stripes, Bullitt-style gauge faces. 18x9 wheels, Sniper tuned, 3,620 pounds
1991 Ford F250 - Air restrictor delete. Cat delete.
1991 T-Bird 'Interceptor II' (12 CP 2013-) - Race-prep, Full custom "interior", Carb'd 302, Trick Flow twisted wedge heads, stage 1 cam, Custom Koni coil-overs front, Koni yellows rear, Cobra front brakes, fuel cell, 18X9 wheels, 275/30 Hoosier A6, 4.11 T-Lok. 3000 pounds
2004 Toyota Solara SE - V6, Sport package, Muffler delete, 17X7 wheels, 235/50 Conti ExtremeContact DWS
Kelsey Smith is offline
post #3 of 5 (permalink) Old 12-10-2006, 12:08 AM
I'd look into a splitport 3.8 or 4.2. You'd get a big boost of HP using one of those, then you can add a vortech later for more power then you'd probably ever get from the single port
NiteFire is offline
post #4 of 5 (permalink) Old 12-10-2006, 10:18 AM
Who is John Galt?
Check v6power.net out for some setups. There are a lot of guys over there who are into 3.8/4.2 tech (and I mean hard core).
"Won't work, can't be done"
cougar_guy04 is offline
post #5 of 5 (permalink) Old 12-11-2006, 01:10 PM
youe engine is 99% the same as a 96' Mustang V6, the only difference is the exhaust manifolds (for fitting different chassis). As-is your engine is good for 10psi boost with a safe tune. Mine still running great with 25,000 miles of vortech abuse Personally I would start with finding a used 3.8L mustang supercharger kit, 30# injectors, 02' GT MAF, 4.2L truck sparkplug wires, and an SCT X-cal2 and enjoy a high-mid 14 second car with no other changes. Could easily be done for under 2500$ if you don't mind making a intake tube for the Vortech (mustang one won't fit) and moving the Coil pack (to allow room for the intake tube you make).
rancherlee is offline
