splitport conversion question - TCCoA Forums
post #1 of 10 (permalink) Old 12-20-2006, 05:15 PM Thread Starter
got hold of 2000 splitport mustaang engine w 12k, question is should i just change top end of my 96 3.8 w splitport top end for the more aggressive cam in 96 or change whole motor?
mgretro is offline
post #2 of 10 (permalink) Old 12-20-2006, 06:16 PM
Blindloser1080's Avatar
from what I have been told, if you change the whole motor, you're gonna need to look at beefing up your tranny, and the rear-end on your 96 bird.
Blindloser1080 is offline
post #3 of 10 (permalink) Old 12-20-2006, 06:50 PM
4.3Lcougar's Avatar
typically you just swap out the heads, and intake manifolds (upr/lwr) but if you have the entire motor i'd put that in. it will put out more then swapping out the parts!
1985 THUNDERBIRD CFI 5.0L..
4.3Lcougar is offline
post #4 of 10 (permalink) Old 12-20-2006, 07:37 PM
In all honesty, it wouldn't really matter either way. I would swap out the complete engine, simply because it is easier (in my opinion) and the 2000 engine probably has less miles on it than your 96 engine.
-Rod
post #5 of 10 (permalink) Old 12-21-2006, 04:45 PM
The_Ghost's Avatar
Swap in the mustang motor, BUT use the 96's cam...
96 Laser Red 4.6L - Custom
Custom Nascar-Inspired Bodykit - 55* Rear Spoiler - J-modded Trans - 80mm MAF - One-Off Diablosport Chipmaster Revolution Chip/Tune W/Toggle - ScanGaugeII Diagnostics & Data Readout - PBR Brakes - Drilled/Slotted Rotors - SC Wheels & Springs - Falken Tires - KYB GR-1 Shocks/Struts - FSTB - RSTB - RTLB - LECB - 60/40 Split Rear - SC Seats - SC Vac/Boost Gauge
The_Ghost is offline
post #6 of 10 (permalink) Old 12-21-2006, 04:47 PM
The_Ghost's Avatar
While you're at it, go 5-speed m5r2.. .did the motor you got come with IMRC's?
post #7 of 10 (permalink) Old 12-21-2006, 05:59 PM
A 2000 shouldn't have IMRC's.
-Rod
post #8 of 10 (permalink) Old 12-22-2006, 12:27 PM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
yeah just stick the whole engine in there, it's got lower miles. Just make sure to use the balancer and flexplate of that year engine.
Thomas is offline
post #9 of 10 (permalink) Old 12-23-2006, 09:49 PM Thread Starter
balancer
got everything but flex plate, though this motor was internally balanced? Anyoe got suggestions on where to get a good flexplate?
mgretro is offline
post #10 of 10 (permalink) Old 12-24-2006, 12:56 AM
SplitPortBird's Avatar
if its internal balance get a flexplate for a 2003 mustang 3.8L
SplitPortBird is offline
