possible coolant leak - TCCoA Forums
post #1 of 4 (permalink) Old 12-26-2006, 01:59 AM Thread Starter
ok to start off wheni i start the car sometimes the car will run really rough and shakes like crazy and to add on to it my car eats coolant when i was filling the coolant the other day i knowticed that there was a puddle of coolant of coolant right in front of the inteake manifold next to the driver side head i could swear the i saw drips of coolant coming from the seal between the intake manifold and head
the problem is that i wiped all the coolant away and it didnt come back and the system pressurized and i never drop any coolant on the ground
could this just be an intermitent leak and a possible blown head gasket?
and i also knowticed that even after a 2 hour drive i will still have a little steam coming from the tail pipe just enough to leave a wet spot on the ground after like 5 minutes
i have a bone stock 3.8 and its a 96
thank you
fast86rx-7 is offline
post #2 of 4 (permalink) Old 12-26-2006, 07:36 AM
I would suspect a head gasket. Remove your plugs and see what they look like. If you were to replace the head gasket , the intake leak would be taken care of at the same time as you have to remove that to do them.
birds4us is offline
post #3 of 4 (permalink) Old 12-26-2006, 12:59 PM Thread Starter
i was thinking it might be im just glad i bought the car with a warantee and will be covered no charge to me
that is why i am getting a fully rebuilt tranny and torque converter
post #4 of 4 (permalink) Old 12-26-2006, 01:14 PM
Gcline's Avatar
free is good
Daily Driver, 38mpg!
Gcline is offline
