Car apperently running too cool - is my t-stat in backwards? - TCCoA Forums
post #1 of 10 (permalink) Old 12-28-2006, 04:11 PM Thread Starter
My girlfriend has a 96 N/A 3.8 t-bird with 196k. I've never looked at the temp. guage before, but lately i've been noticing that the temp. never climbs high enough to turn the radiator fan on, usually it runs well below the "N" in "NORM", even in 55 degree weather. I've had a 3.8L before with a broken thermostat that was stuck half-way open and it exhibited these same symptoms. But when i changed the t-stat, i noticed the one in there didn't appear broken. With the new t-stat in, it cooled the same, the guage never went above the "N" in norm and the fan never turned on even after idling for 25 minutes in 45 degree weather.
When i changed the t-stat, i put it in the same way the old one was in, with the spring side going towards the hose, and the cone side going towards the motor. When looking in my 1995 ford service manual to see how much to torque the bolts, i noticed the picture showed the t-stat going in the OPPOSITE way. Is it possible that between 1995 and 1996 they made the t-stat go in the opposite way, or was the original t-stat in there BACKWARDS? Is it possible for a t-stat that's in backwards to cause PARTIAL opening resulting in the coolant never getting quite hot enough?
Thanx for any input, i know the car's got a lot of miles, but it runs strong and i'd hate to blow a head gasket!
mattcorby is offline
post #2 of 10 (permalink) Old 12-28-2006, 05:55 PM
Yes it is in backwards. Also be sure that the thermostat does not slide down when you install it again. I've pulled 2 apart recently and they both had slipped when they were installed.
birds4us is offline
post #3 of 10 (permalink) Old 12-29-2006, 05:55 AM
mybird_91's Avatar
Send a message via Yahoo to mybird_91
that or stuck open like mine was......
1994 Chevrolet Camaro Z28
LT1 350
K&N Intake and Flowmaster Exhaust
1995 Lincoln Mark VIII
hollow front cats, 3rd cat still there, no resonator, replaced by a single 40 series flowmaster, 2 3"x18" tips out back. screamin demon coil packs, mallory pro wires, motorcraft platinum plugs. intake resonator delete.
mybird_91 is offline
post #4 of 10 (permalink) Old 12-29-2006, 01:33 PM
The Stevinator's Avatar
yup deff. backwards, as for the fan. turn the ac on max cool to see if it's running right. as for the gauge, the sensor wire easily comes off. if it isn't working, thats the likely culprit.
The Stevinator is offline
post #5 of 10 (permalink) Old 12-29-2006, 02:41 PM
doesn't the new stat have "this side to radiator" on it somewhere?
post #6 of 10 (permalink) Old 12-29-2006, 02:51 PM
i can't remember from the last time i changed mine.
post #7 of 10 (permalink) Old 12-29-2006, 08:31 PM
It is nice
none of the ones i have seen have writing like that on them. You definately have it wrong. the spring goes towards the motor.
91CougarLS is offline
post #8 of 10 (permalink) Old 12-29-2006, 09:00 PM
If you use Motorcraft it actually wedges in the t-stat cover (twist to lock/unlock), which would prevent slippage. on a N/A tbird, I'm not sure on an SC.
KewlBird is offline
post #9 of 10 (permalink) Old 12-30-2006, 01:37 PM
I'm lucky if mine makes it to the N. its usually always just above the blue square!!! I just got the TSTAT changed too. now it warms up quiker but still doesn't get any hotter.
MN12BIRD is offline
post #10 of 10 (permalink) Old 12-30-2006, 05:34 PM
thewishkah's Avatar
Send a message via AIM to thewishkah
yeah my temp gauge doesnt sit much above the blue box ethier, but I know it works because it got nice and hot when my fan motor went up in smoke.
thewishkah is offline
