3.8 pep - TCCoA Forums
post #1 of 2 (permalink) Old 01-06-2007, 07:03 PM Thread Starter
Angry 3.8 pep
i have a 94 lx with a 3.8... the motor has 190,000 miles on it... it runs strong now that i jus replaced $678.92 in sensors on it... what can i do to improve the power... i'm looking for most bang for the buck mods... is there any stroker kits for the 3.8??? better heads... should i rebuild the short block? how much & where can i get a shift kit & tranny cooler??? what gears should i put in rear... it's a daily driver & every friday night starting in spring i want to race it when the strip opens... what rear do i have & is it posi or lsd??? thanx...
jeleighlover is offline
post #2 of 2 (permalink) Old 01-06-2007, 07:16 PM
Who is John Galt?
read through this:
http://forums.tccoa.com/showthread.php?t=7727
yes, you can get stroker kits through morana, SSM, or just get a 4.2 setup from a F-150
Read through the trans articles here:
http://www.tccoa.com/articles/tranny/index.html
Also, if you want a built transmission, contact Darrin. He also sells pre-modded valve body kits. Trans cooler can be had from Jeg's or Summit
Personally, I'd say 3.73's or 4.10's. I'd suggest getting an 8.8 and track-lok while you're at it. Several members on the board can build you one
If it is going to be raced and daily driven, go for 3.73's. You could also go for 3.55's. miller1995 runs these and I haven't heard any complaints
posi is a chevy thing. The correct term is Track-lock (unsure of the spelling). To find out what gears you have, read this:http://www.tccoa.com/articles/gears/gears.html
Answers bolded
"Won't work, can't be done"
cougar_guy04 is offline
