positrack rear end - TCCoA Forums
post #1 of 14 (permalink) Old 01-09-2007, 07:13 AM Thread Starter
positrack rear end
my tibrd is in the shop right now for some issues that are coverd by warranty, anyways, when i get it back i was thinking about buying the positrack rear end from a v8 cougar from a local junkyard and swapping out rear ends, i was wondering if anyones done this and what the results are like and stuff
thanks
95SilverLX is offline
post #2 of 14 (permalink) Old 01-09-2007, 09:46 AM
Check out the Drivetrain Forums. keep in mind "positrac" is a GM term, Trac-loc is the Ford term.. Trac-loc will yeild you more results when doing a search on it.
Justin McC
Stinkfist04 is offline
post #3 of 14 (permalink) Old 01-09-2007, 01:41 PM
Traveler's Avatar
This is true. "Posi-trac" and "Trac-Loc" are both brand names for what is commonly called a "limited slip" rear end. Its misleading because neither is actually a "locked" rear end.
However to answer your question.
Yes, its been done many times. I myself have done it. Bear in mind that while you are searching the yards, that not all mn12's got the track-loc, V8 or not. The most accurate way to determine if the center section ("pumpkin") is a limited slip is to check out the metal tag that is held on by one of the bolts (usually near the top) that holds the rear cover on. If the code has an "L" in it, its a limited slip. for example "3L27" is a 3.27 Trac-Loc.
The easiest way is to is to check the rear end code from the tag glued in the drivers side door jamb. The codes are on this chart:
http://www.tccoa.com/articles/gears/gears.html
Other good tech articles to read:
http://www.tccoa.com/articles/gears/index.html#
Keep in mind that it is possible that someone could have changed rear ends before the car made it to the salvage yard so the door jamb, though easier, isn't as accurate as the tag on the rear end itself. When/if you find one, be sure it is low mileage, and even then you probably ought to have it rebuilt. The first one I installed lasted about a year before the clutches wore out and it acted like an open rear end. The second one I installed is still good. (it was much lower mileage when I installed it).
Results? Great, I love it. Car launches much better with it.
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #4 of 14 (permalink) Old 01-09-2007, 09:01 PM Thread Starter
thanks guys if i need any help or suggestions ill contact u guys
post #5 of 14 (permalink) Old 01-10-2007, 02:25 PM
mybird_91's Avatar
Send a message via Yahoo to mybird_91
i'm running 3.27 gears need better!!!!!!!!!!!!!
1994 Chevrolet Camaro Z28
LT1 350
K&N Intake and Flowmaster Exhaust
1995 Lincoln Mark VIII
hollow front cats, 3rd cat still there, no resonator, replaced by a single 40 series flowmaster, 2 3"x18" tips out back. screamin demon coil packs, mallory pro wires, motorcraft platinum plugs. intake resonator delete.
mybird_91 is offline
post #6 of 14 (permalink) Old 01-10-2007, 02:27 PM
Traveler's Avatar
I'm putting 3.55's in this spring.
Low Miles
Wifes Car
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #7 of 14 (permalink) Old 01-10-2007, 06:21 PM
Don't forget! Sure-Grip is the MoPar term!
http://images19.fotki.com/v358/photo...Tbird01-vi.jpg
1994 White (WT) TBird - 4.6 L SOHC with 4R70W
"Sir, if you were my husband, I would poison your drink."
-Lady Astor to Winston Churchill
"Madam, if you were my wife, I would drink it."
-His reply
Rehab progress link
Today's Progress
DScruggs is offline
post #8 of 14 (permalink) Old 01-10-2007, 07:01 PM
Traveler's Avatar
LOL Sure-Grip? Sounds like something to hold your dentures in!
Low Miles
Wifes Car
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #9 of 14 (permalink) Old 01-10-2007, 07:44 PM
SuperNewbie
supergordo's Avatar
"now that i use sure grip, i dont have to worry about eating apples and peanut brittle! And it leaves great tire tracks as well! I love my Sure grip"....available at Walmart and all dodge dealers..
1995 Cougar XR7 4.6
1997 Thunderbird LX 4.6
1977 Country Squire 460
1985 Capri RS 5.0, 5spd
1997 Thunderbird 4.6
1984 Capri RS 5.0,5spd
supergordo is offline
post #10 of 14 (permalink) Old 01-11-2007, 11:53 AM Thread Starter
hey can i just use my stock rear end housing and install trac-loc and put in bigger gears like 3.73s.
post #11 of 14 (permalink) Old 01-11-2007, 12:26 PM
Short answer is yes. BUT you've got a 7.5 under the V6. The 8.8 (from a V8) is more prevalent, easier to find parts for, and will hold up if you ever make any kind of real power.
Sometimes, we just need to remember what the rules of life really are:
You only need two tools: WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
doodaa is offline
post #12 of 14 (permalink) Old 01-11-2007, 12:41 PM
Traveler's Avatar
Actually, if you're really interested, I might know of a salvage yard that actually has a low mileage, 7.5 3.27 trac-loc center section for sale. I can check with them and see if they've still got it if you want.
Low Miles
Wifes Car
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #13 of 14 (permalink) Old 02-23-2007, 07:43 PM
What are the HP limitations of the 7.5?
Iam looking at about 245hp and wondering how much further I can go before I am forced to change out the exhaust I JUST put in (limited to 275hp) and my rear end.
mn12v6x2 is offline
post #14 of 14 (permalink) Old 02-23-2007, 07:54 PM
The Great Obucina's Avatar
the 7.5 is a grenade-o-matic.
"Booyah". Stu Scott.
The Great Obucina is offline
