volt meter crazy- - TCCoA Forums
post #1 of 4 (permalink) Old 01-21-2007, 03:32 AM Thread Starter
Send a message via AIM to BeasTx
volt meter crazy-
ok i just replaced the alt in my 93 3.8.. because of a voltage problem when i would rev engine.. ( bat light would come on ) it stopped until the other day... now it's back but was difffernt, the bat light would just stay down and no response from volt meter.. so i bought a new voltage regulator.. now i'm back to whre i was from teh beginning, car seems like it's running fine, but when i rev engine.. the volt meter skyrockets.. so i dont know what to do .. maybe the belt? :-/ chime in asap please.
1995 thunderbird lx 4.6L-
gutted cats, flowmasters in rear
K&N, hypertech chip.
BeasTx is offline
post #2 of 4 (permalink) Old 01-21-2007, 03:37 AM
JMags's Avatar
Did you check the wiring to the alt? No shorts? Also was the battery fully charged before you replaced the alt and fired it up? You can take one out with a weak battery.
JMags is offline
post #3 of 4 (permalink) Old 01-21-2007, 03:42 AM Thread Starter
it was in the car for maybe 2 miles before i replaced alt, but was a brand new battery for the most part.
and the wires look fine
BeasTx is offline
post #4 of 4 (permalink) Old 01-21-2007, 03:59 AM
JMags's Avatar
do you have access to a volt meter/multimeter? I would like to see the voltage on the battery, car not running, seems like it could be a problem with the battery since its so new, bad cell or something.
JMags is offline
