Misfire when warm - TCCoA Forums
post #1 of 9 (permalink) Old 02-07-2007, 04:59 PM Thread Starter
Misfire when warm
My car has a misfire when I start it up when its hot. Sometimes it does it sometimes it doesnt. Sometimes its so bad the engine dies unless I rev it. Whats the problem?
NiteFire is offline
post #2 of 9 (permalink) Old 02-07-2007, 06:05 PM
When was the last time it had a tune up? Dirty MAF, dirty fuel filter? Could be the IAC too. Do you have a CEL?
Jay
FordMan77 is offline
post #3 of 9 (permalink) Old 02-07-2007, 09:35 PM Thread Starter
no CEL, last tuneup was 12k miles ago
NiteFire is offline
post #4 of 9 (permalink) Old 02-11-2007, 11:26 AM
The Stevinator's Avatar
try replacing your ignition module. they start to act up when they get warm. it's the grey box thats bolted to a metal box near your air filter. i had to same problem.
The Stevinator is offline
post #5 of 9 (permalink) Old 02-17-2007, 02:56 PM
An IAC would not cause a misfire. I would check the plugs/wires, especially the wires. There is no ignition module on the car so don't go and try replacing that. It's likely to be either the plugs, wires, or the coil. Start at the cheapest and work your way up. You can check the condition of the plugs and spray water on the wires in a dark place or at night to see if the wires are still good.
post #6 of 9 (permalink) Old 02-17-2007, 04:08 PM
im not sure if DIS's have a ignition module or not. i have a 94 which is still distributor driven. but that was the symptoms/fix that solved my problem.
post #7 of 9 (permalink) Old 02-17-2007, 04:33 PM
Merlon's Avatar
same problem with mines..i fixed it with plugs and wires, so either or could have been the problem...
you might also want to run some injector cleaner, make sure your getting enough fuel when hot.
00 GT transmission,Jmod,30,000 gvw transmission cooler
Air silencer removed(cone filter added w/ heatshield)
shaved emblems, doors, trunk, and antenna
Clear corners
chrome 95sc rims
20% tint all the way around,
6gallon air tank capacity, Viair 400c commpressor
175psi pressure switch
custom guages by Scott H.
http://www.cardomain.com/ride/2733945
Merlon is offline
post #8 of 9 (permalink) Old 02-17-2007, 11:39 PM
It's not a matter of whether it's DIS or not. It's a matter of whether it's full OBDII or not.
post #9 of 9 (permalink) Old 02-18-2007, 09:31 AM
ah. gottcha
