Starting Problem - TCCoA Forums
post #1 of 11 (permalink) Old 02-09-2007, 10:24 PM Thread Starter
Unhappy Starting Problem
Have a 94 XR 7 with a 3.8 in it. Over the past couple of weeks the car want start after having been already running. Now here is what happens after the engine is shut off and restarted. Put key in the ignition turn key to start nothing happens, all dash lights come on so I have to play with it for about 3 to 5 mins before it will start.
Now when I say play with it, I mean turn the key off an on, several times. Anyone have any ideas as to what maybe causing this?
Dartanion is offline
post #2 of 11 (permalink) Old 02-09-2007, 11:05 PM
reply
That sounds like a starter problem. My car used to do that when the starter got hot. I replaced it with a new one and the problem went away. =)
scotteiboi is offline
post #3 of 11 (permalink) Old 02-10-2007, 09:26 AM
Do you hear the fuel pump prime when you turn the key and it doesn't start? Reason I ask is my Vic did this twice and both times it turned out to be the ignition switch. Just a thought.
Jay
FordMan77 is offline
post #4 of 11 (permalink) Old 02-10-2007, 03:29 PM
twin turbo 281's Avatar
If it is the starter try hitting the starter with a hammer or something and see if it starts then go from there and listen for the fuel pump
2x95 cougars to the scapper
51 Mack A51T restoration
twin turbo 281 is offline
post #5 of 11 (permalink) Old 02-10-2007, 10:56 PM
When you play with the key, does it click, and try to engage, or does it just start perfectly when you get it to work? You are either getting a connection to work in the switch, or the solonoid is almost shot. Usually when the starter goes either the pinion throwout or the rotational motors wont function. It will engage, but wont turn, or it will turn but not engage. If the engine compartment mounted solonoid is bad, it should be evident because you wont hear it click.
Try this, when it doesn't want to start, turn on the fan blower motor. If it doesnt turn off when you go to the start position, It's the ignition switch.
p.s. Starters can draw up to 800 amps on cold winter mornings if it's availible. You might also make sure all the wires are good and snug. Bad connections can make it behave just as a failed part would.
Distortion 5.0 is offline
post #6 of 11 (permalink) Old 02-10-2007, 11:52 PM Thread Starter
Starting Problems
Ok Thanks for all the input. To answer some questions that was asked, yes when the key is turned on, you can hear the fuel pump hum, and when it does start it starts great. I hear No clicking when it doesn't START, i Just have to keep turning the key off an on several times then it will start perfectly.Let me ad this when it has been sitting for a while it will start my problem only happens after it has been running doesn't matter if has been running for 30 mins or 3 mins.
post #7 of 11 (permalink) Old 02-10-2007, 11:53 PM
reply
Yeah its definetly your starter. That matches my problem down to the T.
post #8 of 11 (permalink) Old 02-11-2007, 02:02 AM
Yep, sounds like the starter is failing after getting heat-soaked. The solenoid is mounted to the starter and not on the fender/in the engine compartment as it was stated above. A new starter will fix er right up.
post #9 of 11 (permalink) Old 02-11-2007, 11:24 AM
The Stevinator's Avatar
yeah, it is the starter solenoid. but do yourself a favor, just replace the solenoid unless you got gobs of money laying around. it'll be much cheaper that way.
The Stevinator is offline
post #10 of 11 (permalink) Old 02-11-2007, 11:36 AM
[QUOTE=master486] The solenoid is mounted to the starter and not on the fender/in the engine compartment as it was stated above. /[QUOTE]
K
I know my 5.0 has one in both positions, one on the firewall and another on the starter itself. Wasn't sure if these cars had the same setup or not.
post #11 of 11 (permalink) Old 02-11-2007, 06:41 PM
yeah his is a 94 not sure about the firewall mount?
