rough idle - TCCoA Forums
post #1 of 4 (permalink) Old 02-14-2007, 11:16 AM Thread Starter
rough idle
1994 T Bird, 3.8 Auto.
I have been working on a rough idle, at all times. I was about to injector replacement. I decided to give diagnostics one more try. I did have a code 181 and 189. New O2 sensors have been installed.
I found the timing was at 15 degrees advanced, so I reset it to 10 degrees, with the spout removed.
Long story short, it idles smooth as silk. So why did 5 degrees advance make such a difference?
wgloff is offline
post #2 of 4 (permalink) Old 02-14-2007, 09:00 PM
reply
Because the spark plug is firing at the wrong time which means the combustion cycle is off, putting alot pressure trying to force the piston down when it wants to come up. Thats why it idles rough because all of the pistons will experience this.
scotteiboi is offline
post #3 of 4 (permalink) Old 02-23-2007, 02:31 PM
I thought for some reason our engines should be like 3 deg retarded? Am I wrong?
roger is offline
post #4 of 4 (permalink) Old 02-23-2007, 07:22 PM
reply
In a sense you are right. The SPOUT plug retards the timing after you set the base at 10 degrees BTDC. But as for retarding the base timing 3 degrees, i'm not entirely sure.
