Compressor Input wire - TCCoA Forums
post #1 of 5 (permalink) Old 02-19-2007, 06:42 PM Thread Starter
Resident Line Creator
th3subtl3on3's Avatar
I got a fan controller from DCC and it works great. I want to hook it up to my AC, but I can't find the compressor input wire. It takes the signal from there to run the fan at 50% when the AC is activated. Thanks.
-Brian
th3subtl3on3 is offline
post #2 of 5 (permalink) Old 02-20-2007, 03:45 PM
JMags's Avatar
I dont know about your car but on my 97 there is a small connector on the back of the compressor that plugs in. You would need to figure out if you need a positive or negative signal for your fan controller and tap the appropriate wire. Have fun with the multimeter.
JMags is offline
post #3 of 5 (permalink) Old 02-20-2007, 03:58 PM Thread Starter
There is a small connector with two wires towards the front of my compressor, near the belt. I tried using a test light to see if that was it, but nothing was happening.
-Brian
post #4 of 5 (permalink) Old 02-20-2007, 05:09 PM
JMags's Avatar
I know that that controls the compressor because I had unplugged it at one point and the compressor wouldn't come on.
If you want I can grab a multimeter from my house and I can meet you somewhere. I am on vacation through thursday. PM me if you want.
JMags is offline
post #5 of 5 (permalink) Old 02-21-2007, 08:56 PM Thread Starter
were having a little get together thursday if you want to swing by.
-Brian
