more new's - TCCoA Forums
post #1 of 4 (permalink) Old 12-15-2002, 11:42 PM Thread Starter
more new's
well this is for those who gave me the advice (cougar howling/vibrating)thak's alot i really appricate it i did a motor mount and it turn's out it's the front mount's as for the vibration i put in about 2 bottle's of fuel injection cleaner and most of it went away. but it's the mount's and now i gotta try a way to fix them . . . . . . . . . . .. . . . . .. . . . and how would you do that and is this going to be a hard project?
cougar 3.8 is offline
post #2 of 4 (permalink) Old 12-16-2002, 01:11 AM
PJ-4.2L's Avatar
Send a message via AIM to PJ-4.2L
Without the right tools, it's tough. See if you can rent an engine hoist/cherry picker.
PJ
PJ- 4.2L -
" 'DIY' was not meant for women."
PJ-4.2L is offline
post #3 of 4 (permalink) Old 12-16-2002, 08:59 AM
Send a message via Yahoo to 59bisquik
I have my engine out right now and I had both mounts broke!! I would say with out a engine hoist it will be more difficult. Its going to be a tight squeeze but im sure it can be done.
94 3.8 Thunderchicken
59 Chevy Biscayne undergoing frame off rodstoration 383/Hilborn Stack EFI
54 Ford Customline Coupe 351/AOD
59bisquik is offline
post #4 of 4 (permalink) Old 12-16-2002, 04:23 PM
I did mine with just a floorjack on the oil pan, just use some common sense and it works great, stick flat piece of wood between the jack and the oilpan and lift it an inch or 2
rancherlee is offline
