vaccum leak? - TCCoA Forums
post #1 of 2 (permalink) Old 03-03-2007, 03:55 PM Thread Starter
thewishkah's Avatar
Send a message via AIM to thewishkah
vaccum leak?
Hey guys, I have recently started to hear a low picth howl or whistle when im applying the gas at a normal pace not gunning it or barely touching it. I notice it mostly after I let off the gas it kind of sounds like a whirring sound, I was thinking a vacum line but I can't find any that look to be in bad shape or dissconected.
I know it might be the IAC but I thought that usually sounds more high pitched. I know its coming from the engine compartment and not the rear end so I have ruled out the rear gears going bad, but I am not sure what else it might be. I dont want to take my IAC off and clean it or replace it if I don't have to so any other ideas would be a great help. Thanks, Jon.
thewishkah is offline
post #2 of 2 (permalink) Old 03-03-2007, 09:17 PM
Could be a leak in the intake tube between the MAF and throttle body. Check that those clamps are tight and that the PCV hose is securely in. Also, just do a general check of all rubber lines for any cracks.
