cruise cable - TCCoA Forums
post #1 of 4 (permalink) Old 03-13-2007, 09:44 AM Thread Starter
4.3Lcougar's Avatar
cruise cable
i curious if there was or is a way to remove the cruise control cable. did the split port swap and the cable is short about a inch, its all the way extended, and it still reaches the TB but it pulls the throttle open just a little bit for a slightly high idle...is there a compatible cruise control cable or a way to delete the system. thanks
1985 THUNDERBIRD CFI 5.0L..
4.3Lcougar is offline
post #2 of 4 (permalink) Old 03-13-2007, 11:23 PM Thread Starter
4.3Lcougar's Avatar
Originally Posted by sinhumane View Post
why not just make a plate that the cable connects to, and weld/solder an extention to the tb with a connector the same as the cc cable end?
sounds complicated, but i could make a plate.. it just wont look as clean as id like it to look
post #3 of 4 (permalink) Old 03-21-2007, 01:26 PM
you may take a look at the splitport aftermath post I have up, I have the same problem. Rod made a plate that looks pretty simple, and allows you to bolt on you original mount for the cable. However the length is still an issue. From what I understand you have to remove the quarter panel and re-route the cable, then it will reach with no problem.
mn12v6x2 is offline
post #4 of 4 (permalink) Old 03-22-2007, 12:47 AM Thread Starter
4.3Lcougar's Avatar
intresting.. im thinking that ill probably fab up and racket for in untill i have a reason to pull the fender.. thats for the help... ill check out your post..
