ran into a problem today...... - TCCoA Forums
post #1 of 12 (permalink) Old 03-13-2007, 02:36 PM Thread Starter
well since it was really nice outside here in toronto about 10 degrees, I decided I would start getting the thunderbird ready to take out of storage, I pop the hood only to find a Huge mess, corrosion all over the battery cables, and surrounding metal. Right away I took it all apart, and cleaned it as good as I can, but my problem is, I did have some corrosion problems before, actually it all started last year, it wasn't bad so i brushed it off, now today its horrible, lookms liek that battery might have been leaking acid. Any suggestions would help.
90TBird is offline
post #2 of 12 (permalink) Old 03-13-2007, 03:13 PM
Resident drifter
slidebird91's Avatar
get a new battery and cables.
slidebird91 is offline
post #3 of 12 (permalink) Old 03-13-2007, 03:14 PM
reply
Did you use a wire brush to clean the contacts? When a battery starts leaking there isn't much to be done except get a new one. =/ Also, if it isn't a maintenance-free battery did someone overfill the water? When did you last drive it? It is possible that the regulator is faulty which will overcharge the battery causing it to leak. Let us know. =)
scotteiboi is offline
post #4 of 12 (permalink) Old 03-13-2007, 04:19 PM Thread Starter
I did use a wire brush to clean the contacts and put dialectric grease also. I will replace the battery cables, they are pretty much useless as they are. The battery is just a traditionall lead-acid one, its rather new actaully mabye less then 4 months old. Where is this regulator located?
90TBird is offline
post #5 of 12 (permalink) Old 03-13-2007, 04:22 PM
The Great Obucina's Avatar
Originally Posted by 90TBird View Post
I did use a wire brush to clean the contacts and put dialectric grease also. I will replace the battery cables, they are pretty much useless as they are. The battery is just a traditionall lead-acid one. Where is this regulator located?
the grey plastic thingy on the backside of the alternator.
"Booyah". Stu Scott.
The Great Obucina is offline
post #6 of 12 (permalink) Old 03-13-2007, 05:02 PM Thread Starter
I actaully just replaced my alternator, and the charge level of the battery seemed fine.
90TBird is offline
post #7 of 12 (permalink) Old 03-13-2007, 05:57 PM
Well if your new battery does the same thing, you know what the problem is.
post #8 of 12 (permalink) Old 03-14-2007, 10:27 AM Thread Starter
the fact that im missing 2 cylinders off the front of my engine depresses me too much
90TBird is offline
post #9 of 12 (permalink) Old 03-14-2007, 02:36 PM Thread Starter
Originally Posted by sinhumane View Post
lol. a nice five-oh would help your depression....
5.0... a tbird owner's prozac.
5.0 will help with the depression but a 460 would put the biggest dumbest grin on my face forever.
90TBird is offline
post #10 of 12 (permalink) Old 03-14-2007, 02:50 PM
so whats stoping you?
post #11 of 12 (permalink) Old 03-14-2007, 07:08 PM Thread Starter
nothing actually, just the fact that I want to put the 460 into a mustang, then a thnderbird. And I don't have a mustang....yet.
90TBird is offline
post #12 of 12 (permalink) Old 03-14-2007, 08:25 PM
thewishkah's Avatar
Send a message via AIM to thewishkah
wouldn't it of been better to say it would turn your depression into compression? haha sorry for the lame joke but, I know all about corosion. Remove the battery tray if anything got on it and clean it real nice and while its out add some nice rustoleum black coating (the one that looks like a powder coating) replace the cables and check your grounds! lol Good luck with it.
thewishkah is offline
