Difference between '96 & '97 3.8L? - TCCoA Forums
post #1 of 5 (permalink) Old 03-18-2007, 07:56 PM Thread Starter
Would you explain the difference between the '96 and '97 3.8L engines?
If you know of any differences between the '95 and '96 I'd be interested in hearing that also, know about the longer head bolts
Thank you in advance for your replies.
Brit101 is offline
post #2 of 5 (permalink) Old 03-18-2007, 10:32 PM
There is no difference whatsoever between 96 and 97.
Between 95 and 96 the heads, intake manifold, and exhaust manifolds all changed. The exhaust manifolds became tubular headers and the intake manifold was designed to accept fewer (12 as opposed to 14) and smaller bolts. There were also a lot of changes in the sensors that were used. All 96+ engines were OBDII where as earlier engines were OBDI. As far as internal differences (cam, crank, block, etc.) I do not know.
post #3 of 5 (permalink) Old 03-18-2007, 11:51 PM
5oh Transformer
ZeroRain's Avatar
Send a message via AIM to ZeroRain
i know in 96 they fixed the 3.8 head gasket problem. i also think thats when they went Distributor less ignition. not sure tho.
1996 Ford Thunderbird LX EFI Swapped 311 5spd "TT 5oh project"
1998 Ford Taurus SE 24v Duratec auto "DD"
1966 Ford Galaxy 500 352 Cruise-O-Matic "Restoration Car"
We don't just dream about fast toys, we build them!
ZeroRain is offline
post #4 of 5 (permalink) Old 03-19-2007, 01:02 AM
Yes to your second statement and pretty much yes to your first. It was drastically improved, but not cured.
post #5 of 5 (permalink) Old 03-19-2007, 01:02 AM
Blindloser1080's Avatar
Yea, trust me......not cured Best time I've ever had workin on my car. I've never learned so much before!
Blindloser1080 is offline
