Double the headgasket problem?? - TCCoA Forums
post #1 of 5 (permalink) Old 12-17-2002, 11:37 PM Thread Starter
I was wondering if anyone who has had their headgasket fixed had it blow a second time??
XR7kid is offline
post #2 of 5 (permalink) Old 12-18-2002, 12:51 AM
Cougar Pilot
BlackCat94's Avatar
I haven't personally, but some people here have
TCCoA, there's no better way.
BlackCat94 - The Revolution.
BlackCat94 is offline
post #3 of 5 (permalink) Old 12-18-2002, 12:22 PM
That's why it's so important to have an auto machine shop pressure test and plane the heads after a head gasket lets go. Aluminum heads warp easily if the car has been overheated, which leads to a head gakset failure down the road. If you're too cheap to send the heads out, don't be surprised if you're replacing them again in another 30-50K. Also, new head bolts and premium gaskets help the situation as well.
teebyrd92 is offline
post #4 of 5 (permalink) Old 12-18-2002, 01:07 PM
New head bolts are not optional... If you reuse them you'll be replacing the gaskets again for sure.
doodaa is offline
post #5 of 5 (permalink) Old 12-18-2002, 02:13 PM
Right....
