Plug wires and coil pack - TCCoA Forums
post #1 of 9 (permalink) Old 03-30-2007, 12:59 PM Thread Starter
Stroked and Blown
BlakTbird96's Avatar
Ok, I just change the sparkplugs in my car. (3.8 n/a) I used autolite double platinums. Now, should I change the wires and coil pack also and is this a easy thing to do? How difficult and how long does it take because I want to get this done today maybe. The car has 92K on the clock.
My other home:
Mid-AtlanticMN12's
'96 Ford Tbird 3.8 SC
BlakTbird96 is offline
post #2 of 9 (permalink) Old 03-30-2007, 02:09 PM Thread Starter
Stroked and Blown
Okay, it doesn't look difficult. What are the best plug wires to get and coil pack?
My other home:
Mid-AtlanticMN12's
post #3 of 9 (permalink) Old 03-30-2007, 03:28 PM
Leave the coil packs alone. No need to change those as long as they are working correctly. Just change the wires (one at a time to avoid a mixup) and call it done. Grab some Motorcraft wires.
Jay
FordMan77 is offline
post #4 of 9 (permalink) Old 03-30-2007, 03:36 PM Thread Starter
Stroked and Blown
Okay now another question. How the hell do I get those clamps off, which hold the wires in place so they don't rub against anything hot? They look as if they should just clamp and unclamp, but I can't seem to get it with my hands or even by prying it off with a screwdriver. If you're not sure what I'm referring to, there are 4 clamp things, which have a few wires running threw them on both sides (2 on each side) to stop them from rubbing against something hot. I need to get these open so I can take the old wires out and slide the new wires in them. Is there a trick to getting these buggers open?
This is what it looks like
My other home:
Mid-AtlanticMN12's
post #5 of 9 (permalink) Old 03-30-2007, 06:42 PM
The part that clamps around the outside of the wires needs to slide out to the left or right, I can't remember which.
Jay
post #6 of 9 (permalink) Old 03-30-2007, 07:56 PM Thread Starter
Stroked and Blown
These things I'm talking about are called Spark plug wire seperaters. Should I just break the old ones and put new ones on? How do they come off?
My other home:
Mid-AtlanticMN12's
post #7 of 9 (permalink) Old 03-30-2007, 09:20 PM
I broke two of mine trying to get them off. Haha. If you use a small flathead screw driver you can pry the ends apart without breaking it. These particular clamps do not slide to the right or left so they are a pain to get off. =)
scotteiboi is offline
post #8 of 9 (permalink) Old 03-30-2007, 09:46 PM
Read HERE for wire recommendations.
post #9 of 9 (permalink) Old 03-31-2007, 05:09 PM Thread Starter
Stroked and Blown
Once they break because I will probably have to break mine to get the wires out, which ones should I replace them with and how do they go on?
My other home:
Mid-AtlanticMN12's
