YEA the HG Club - TCCoA Forums
post #1 of 7 (permalink) Old 04-09-2007, 03:25 PM Thread Starter
YEA the HG Club
The other day I became an honorary member of the HG club. Well turns out the headgasket went because the metal that seperates the coolant from the cylinder disappered somehow. Anyways my question is I got it all put back together and now when i crank the car to start the tach bounces around. I dont recall it ever doing that before. Are the plug wires wrong or what would cause that? Also the radiator appears to be leaking along the passanger side now, possibly damaged from over heating, is there any way of fixing it? It looks like it is leaking where the metal meets the plastic. By the way it is a 93 3.8 thunderchicken.
bubbaking is offline
post #2 of 7 (permalink) Old 04-09-2007, 04:22 PM
I wouldn't suggest "fixing" a broken radiator, Its always better to get a new, and possibly even bigger, one. You don't want to risk another blown HG. =)
scotteiboi is offline
post #3 of 7 (permalink) Old 04-10-2007, 09:31 PM Thread Starter
well the rad. is replaced still having problems with the bouncing tach (jumping up when cranking). any ideas about that?
post #4 of 7 (permalink) Old 04-11-2007, 10:55 AM Thread Starter
this morning i finally got it to start after messing with the plug wire order for hours . now i am worried that there might be another problem. It appears coolant is coming out of a spark plug hole. What could cause that?
post #5 of 7 (permalink) Old 04-11-2007, 12:44 PM
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
ohh, sounds like a cracked head. verify where the leak is, and get back to us.
2014 GT
1990 300ZX TT
big mike is offline
post #6 of 7 (permalink) Old 04-11-2007, 08:53 PM Thread Starter
i hope (and doubt) its not the head since i swapped it off a motor that was running till it threw a rod. could it be excess coolant from where I didnt manage to get it all out?
post #7 of 7 (permalink) Old 04-12-2007, 08:09 AM
Motorboatin' SOB
big mike's Avatar
did you get the heads milled? they could have warped and are not sitting flush with the deck. if any coolant was left in the cylinders (there shouldn't be anyway), it would be blown out through the exhaust. find out where this leak is.
2014 GT
1990 300ZX TT
big mike is offline
