engine idea - TCCoA Forums
post #1 of 5 (permalink) Old 12-19-2002, 09:13 PM Thread Starter
engine idea
ok. I had future (like 2 years) plans of dropping a 4.2L v6 in my car...and putting a nice set of heads and the stang intake on it. But...the main diff between the 99+ 3.8 v6 and my 96 3.8 is the heads and intake, right? So..couldnt I get the morana stage 3 heads made for split port intake, and get the 99+ stang intake, plus a few other things and be pretty close or past the stock stang hp output? I think that would be much easier and cost less, since i was planning on those heads on the 4.2 anyway... I just thought that since the 4.2 is what, 210hp and the stang is 200?
if i need to explain my idea more..let me know
i just wanted to get some opinions on this...
thanks
weswing04 is offline
post #2 of 5 (permalink) Old 12-19-2002, 09:34 PM
PJ-4.2L's Avatar
Send a message via AIM to PJ-4.2L
You could go that way, then buy a 4.2 shortblock later if you wanted to. The '99+ 3.8 makes 190 hp. The 4.2 makes 255 lb-ft of torque, though. What you're suggesting has been done many times by the Mustang guys.
PJ
PJ- 4.2L -
" 'DIY' was not meant for women."
PJ-4.2L is offline
post #3 of 5 (permalink) Old 12-19-2002, 09:36 PM Thread Starter
okay thanks
post #4 of 5 (permalink) Old 12-19-2002, 09:54 PM
Lightbulb Here is the information you should ever need to build a kick tail V6
Here are all the links companies you should ever need to build a awesome stroked V-6 if you wanted:
http://www.moranav6racing.com/
http://www.explorer4x4.com/
http://www.jamesduff.com/index.html
http://www.kennebell.net/
http://www.magnumproductsonline.com/
http://www.babcox.com/editorial/ar/ar40123.htm
http://www.geocities.com/MotorCity/D...4/perform.html
http://www.v6power.net/
http://www.vanirtech.com/index.html
http://www.vortechsuperchargers.com/
http://www.jacobselectronics.com/
Very good site as well:
http://www.extremev6racing.com/
http://www.wolferacecraft.com/
www.coymiller.com
This should get you started. there is a company http://www.vanirtech.com/index.html
That builds killer SOHC 4.0 engines.
These links are for information perposes and I hope that they can help you out. Who knows? You may even build a 4.6 stroker/ killer V-6!
Best wishes!
Sincerely,
Troy Brand
NC-TCCoA
Troy Brand is offline
post #5 of 5 (permalink) Old 12-20-2002, 09:37 PM Thread Starter
thanks..
i would put probably 24lb/hr fuel injectors, custom ground cam, morana stage 3 heads, 99+ intake, underdrive pulleys (possibly - might sell stereo first, since im running over 1000w)...and whatever is left on the first two stages of power adding...
hmm..im liking this idea
any more suggestions?
