best spark plug wires for hot plugs - TCCoA Forums
post #1 of 3 (permalink) Old 04-18-2007, 09:33 PM Thread Starter
4.3Lcougar's Avatar
i was poking around my engine the other day because the car was feeling slightly sluggish. well i found my spark plugs were a little loose. well i took them out to look at them because they were already loose and noticed that im burning my plugs... i checked the back of the haynes manual to compare the spark plugs and they were definitely hot... neways i have the MSD coil pack and think that is probably the culprit.. i never updated my wires or plugs so i am in the market, however comma. i want to find a set that has the least resistance. i know that they base the quality of wire on the ohms per foot, and ive found that the accel universals 300+ have a 150ohm per foot... thats the best ive found...
so i wanted to start a feeler as to the best plugs and wiresthat you guys have and think is the best for split port set up's and N/A 3.8L's..
also if anyone is running the iridium spark plugs id like some feedback on the quality..
thanks,
tyler
1985 THUNDERBIRD CFI 5.0L..
4.3Lcougar is offline
post #2 of 3 (permalink) Old 04-20-2007, 02:55 PM
PCD
Confirmed V6 Nut
I've got the FRPP blue 9mm wires (For "Mudstain" V6). I'm quite happy with them.
PCD is offline
post #3 of 3 (permalink) Old 04-20-2007, 03:12 PM
driller's Avatar
Take a look at Performance Distributors LiveWires.
SCP sells them.
driller is offline
