supercharging stock 3.8 - TCCoA Forums
post #1 of 24 (permalink) Old 04-23-2007, 01:43 PM Thread Starter
97cobracat's Avatar
Send a message via AIM to 97cobracat
i have a 97 3.8 and i am getting a sc that needs a lot of work. i was wondering if i could put the supercharger parts on my car. will the internals hold up or would i be wasting my time? hit me back, dan.
97cobracat is offline
post #2 of 24 (permalink) Old 04-23-2007, 01:48 PM
Awaiting E-Mail Confirmation
tinman_72's Avatar
Yes, they will bolt up... no, the internals will not hold up.
tinman_72 is offline
post #3 of 24 (permalink) Old 04-23-2007, 01:56 PM
PCD
Confirmed V6 Nut
Why not drop the SC motor into your 97? A JModded 4R70W ought to be able to survive if it bolts up. I think it should, but I can be wrong on this point.
PCD is offline
post #4 of 24 (permalink) Old 04-23-2007, 03:15 PM
greencurse's Avatar
no no no... you want a supercharged v6? buy an SC.
1997 Thunderbird LX, 4.6L, Performance White.
3.27 TL, 300hp J-Mod, Mid-Mount Magnaflow w/2.25" True Duals to 3" Magnaflow 15* Slash Cut Tips, PI Intake,
FR500 Steering Wheel, FRPP Wires, 180* T-Stat, 22C Plugs, Cobra Vert Rears, RSTB, SC "L" Braces. 175k and still flying!
greencurse is offline
post #5 of 24 (permalink) Old 04-23-2007, 05:01 PM
Grasshopper is offline
post #6 of 24 (permalink) Old 05-01-2007, 04:09 PM
Don't waste your time
But ......if your pockets are deep
Get a new PA built tranny, 8.8 rear, new drive shaft, bigger half shaft. And most importantly, a built engine with forged internals that can handle boost.
After spending around 9k then you are ready for boost. The only question is, who makes kits for N/A Tbirds?
I wouldn't mine getting my hands on a Kenn Bell 1.7L autorotor. The supercoupe guys have found a way to mate one up to their cars, what about us?
dribrednuht is offline
post #7 of 24 (permalink) Old 05-03-2007, 01:38 AM
You can use the Vortec kit from a Mustang 3.8 and it will work. Member rancherlee has this setup and can probably answer any questions when he's on.
post #8 of 24 (permalink) Old 05-03-2007, 02:56 AM
The_Ghost's Avatar
ok ok i've got the best possible solution for you:
swap a splitport 4.2L in, save money, save gas, get good results.
or, if you're feeling cheap, simply buy a splitport 3.8L. They are common and CHEAP. (the 4.2Ls are harder to find and generally more expensive but you do get more hp)
get a 03-04 windstar intake (the 1999-2002 intakes are PLASTIC and are to be avoided at all costs), or F-150 intake. Port-match the Windstar intake.
oh, and pull the 5-speed gearbits out of the SC. (if it is a 5spd, if not, keep your 4R70W)
and pull the SC's 8.8 rear diff.
and the driveshaft.
and the halfshafts.
and the springs.
and the swaybars.
pull SC 8-way adj. power seats.
install parts in your car.
put your parts (springs, sway bars, d/s, rear diff, automatic gearbox) onto the SC.
strip sc.
race gutted SC.
have fun.
the end!
that said, SCs are such a bastard. I owned one, and while it was the fastest car I have ever owned in my life, good jesus, was it a BASTARD to work on. It died when the N/A 3.8L bottom end that was in it happened to snap the crankshaft at the #1 cylinder under boost. That was a sad day. If I had the chance, I'd do it all over again, too. But I'm happy with 4.6L now.. even though it isn't what the 3.8L was. and gets crappier mileage.
-ghost
96 Laser Red 4.6L - Custom
Custom Nascar-Inspired Bodykit - 55* Rear Spoiler - J-modded Trans - 80mm MAF - One-Off Diablosport Chipmaster Revolution Chip/Tune W/Toggle - ScanGaugeII Diagnostics & Data Readout - PBR Brakes - Drilled/Slotted Rotors - SC Wheels & Springs - Falken Tires - KYB GR-1 Shocks/Struts - FSTB - RSTB - RTLB - LECB - 60/40 Split Rear - SC Seats - SC Vac/Boost Gauge
The_Ghost is offline
post #9 of 24 (permalink) Old 05-03-2007, 02:20 PM
The Stevinator's Avatar
well actually a stock 3.8 can hold some boost respectably (as long as you get enough fuel in them). i think thomas had mentioned sometime that they can hold about 8lbs. roughly.
The Stevinator is offline
post #10 of 24 (permalink) Old 05-04-2007, 05:33 PM
Birdman232's Avatar
theres a few guys at V6power that use the Sc's parts on NA bottom ends...As long as it is tuned correctly it will be fine.
Birdman232 is offline
post #11 of 24 (permalink) Old 05-06-2007, 11:55 PM
How much power can 8psi/lbs make on a 112-118rwhp stock 3.8L?
post #12 of 24 (permalink) Old 05-07-2007, 02:55 AM
I'm just gonna guess but maybe 165-175 rwhp.
post #13 of 24 (permalink) Old 05-07-2007, 04:19 AM
Banned
why go through that trouble? stock v8 birds make 170hp stock
get a 96+ v8 already
Porkchop is offline
post #14 of 24 (permalink) Old 05-15-2007, 12:45 PM
Hopefully you are not talking about a v8 engine swap.
post #15 of 24 (permalink) Old 05-15-2007, 01:02 PM
PCD
Confirmed V6 Nut
Actually, from what I read, you can get SC like numbers by just doing a splitport swap to your N/A motor. From there you can put in a cam during the swap and a SCT chip for more go. If you watch what intake you put on, you can go back with a Vortech or a turbo for even more insanity.
PCD is offline
post #16 of 24 (permalink) Old 05-15-2007, 04:04 PM
Banned
not talking about a swap. jus get another ride
Porkchop is offline
post #17 of 24 (permalink) Old 05-18-2007, 08:41 PM
A split port swap will not get SC hp numbers. The 89-93 SC was rated at 215 hp while the 94-95 were at 230 hp.
A split port Mustang was rated at 190-200 hp.
Cammed and chipped with a few other bolt ons has resulted in about 230-250 hp for most Mustang V6 owners.
A 94-95 SC with a 89-93 %10 overdrive pulley will reach that power level. Add exhaust, larger TB and MAF and cold air etc., and you will be between 280-300 hp. The major difference though will be the torque. While big hp is nice, it's big torque that rocks.
Most don't realize that torque is what gets a car to about 3/4 of the way down the quarter mile.
My mildly modded LX pulls pretty decent of the line, but my bro's heavily modded SC literally sucks you back in the seat.
Flex is offline
post #18 of 24 (permalink) Old 05-18-2007, 08:44 PM
you mentioned the split port mustang. is there any difference between that and the split port f-150 that people use for the split port swap?
post #19 of 24 (permalink) Old 05-18-2007, 08:58 PM
The split port in the F150 is the 4.2. Essentially very similiar to the 3.8 but dimensionally a little larger shortblock due to a deeper oil pan.
They were also rated at 210 hp and 255 ft lbs of torque for a little more power and have an entirely different intake design.
http://forums.tccoa.com/showthread.php?t=6680
Flex is offline
post #20 of 24 (permalink) Old 05-18-2007, 09:07 PM
Texas Chapter Director
Send a message via AIM to speed95 Send a message via Yahoo to speed95
It takes more then just those few bolt-ons to hit 280hp.
speed95 is offline
post #21 of 24 (permalink) Old 05-18-2007, 09:09 PM
ROLLINTHUNDER's Avatar
I've had a 91 SC before i got my 95 V8 and I liked my SC better. You'll get into a lot of work making power out of the early 4.6 motors. I'm in the process of swaping in the Mark VIII motor. The SC motor is definatly worth it. If you can, get ahold of a 95 SC motor. The 95 is the last year of the SC and is the only year of the power increase due to the supercharger internal ports being slightly larger. If you have the time go to the Ky chapter and talk to a guy nammed Jeff Bratton. He has a nice SC ang can tell you all about them. Later.
ROLLINTHUNDER is offline
post #22 of 24 (permalink) Old 05-19-2007, 07:58 PM
Pedal Faster
Josh_Keady's Avatar
I've only driven one SC and one 4.6 Bird. I much preferred the power of the SC to that of the 4.6. But I like the Mark VIII's 4.6 more than an SC. Enough low-end to make it fun, but plenty of top end and much more refined-feeling than the 3.8.
Josh Keady
Josh_Keady is offline
post #23 of 24 (permalink) Old 05-19-2007, 09:32 PM
The Mark V III has the DOHC 4.6, the TBirds did not.
Flex is offline
post #24 of 24 (permalink) Old 05-19-2007, 10:14 PM
Pedal Faster
Josh_Keady's Avatar
That's what I was saying, I like the DOHC 4.6 better than the SC 3.8, but the SC 3.8 more than the SOHC 4.6 (in basically stock form.)
Josh Keady
