Timing Gasket Leaking - TCCoA Forums
post #1 of 1 (permalink) Old 04-26-2007, 10:09 AM Thread Starter
Its leaking coolent down the front of the engine. Or its a corner of my lower intake. Cant tell for sure until a couple pieces are removed. The shop said If it is the timing cover I'm screwed about 800 bucks, if its the intake about 400. How common is it for those to go?
And atleast its not the headgasket!
NiteFire is offline
