coolant sensor - TCCoA Forums
post #1 of 19 (permalink) Old 05-04-2007, 03:16 PM Thread Starter
5oh Transformer
ZeroRain's Avatar
Send a message via AIM to ZeroRain
coolant sensor
on my 96tbird i need to know where my coolant sensor wire is? i have no idea. would it be on the old fuel rail? if so then i need to start tracing it down. thanks
1996 Ford Thunderbird LX EFI Swapped 311 5spd "TT 5oh project"
1998 Ford Taurus SE 24v Duratec auto "DD"
1966 Ford Galaxy 500 352 Cruise-O-Matic "Restoration Car"
We don't just dream about fast toys, we build them!
ZeroRain is offline
post #2 of 19 (permalink) Old 05-04-2007, 03:19 PM
The Great Obucina's Avatar
on the intake manifold.
"Booyah". Stu Scott.
The Great Obucina is offline
post #3 of 19 (permalink) Old 05-04-2007, 03:51 PM
The coolant temp sensor for the PCM is on the passenger side of the intake manifold. The coolant temp sender for the gauge is on the driver side of the intake manifold in the fitting for the bypass hose from the water pump.
post #4 of 19 (permalink) Old 05-04-2007, 04:08 PM Thread Starter
5oh Transformer
ZeroRain's Avatar
is it a lone wire? or does it connect to the fuel rail wire?
ZeroRain is offline
post #5 of 19 (permalink) Old 05-04-2007, 04:09 PM
it connects to the wiring harness.
post #6 of 19 (permalink) Old 05-04-2007, 08:48 PM
He posted in the 3.8L section so he gets 3.8L answers from me.
post #7 of 19 (permalink) Old 05-07-2007, 01:24 PM
white lincoln's Avatar
I don't care what they say about you master486, I like your style...
white lincoln is offline
post #8 of 19 (permalink) Old 05-07-2007, 05:03 PM
What do they say about me??? j/k thanks!
post #9 of 19 (permalink) Old 05-07-2007, 07:14 PM
Uhm.... that you tend to drink a lot on other peoples dime...
Just kidding... nothing but praise and glory!
post #10 of 19 (permalink) Old 05-07-2007, 11:41 PM
Hmm, someone must be following me...That statement might have a wee bit of truth to it...
post #11 of 19 (permalink) Old 05-08-2007, 09:24 AM
Nothing like free beer!
post #12 of 19 (permalink) Old 09-08-2007, 09:58 AM
Put that across the back window of your mn12
mn12v6x2 is offline
post #13 of 19 (permalink) Old 04-11-2011, 01:23 PM
S4gunn's Avatar
I had a question about this sensor as I'm building up my tbird 24 Hours of Lemons track car.
Q: Looking at the above picture (not my engine bay, just one I googled online and edited), is the water temp gauge's temp sender the single wire one mounted underneath the coolant air purge valve?
If so, is there any issue with me just removing it and screwing in my aftermarket temp sender from my Autometer gauge in the same spot?
- I don't care if the in-cluster water gauge becomes dead (cheaper than buying another 10-15 of fittings to make add a "T" and install BOTH sensors).
Q: Will the check engine or check gauges light come on with that wire disconnected?
If so, I'll just replace the gauge with a resistor (sized to the original temp sender's resistance).
Thanks in advance for your tips.
BTW, I tried removing the square plug that seems to go into the intake (thinking it may be another coolant channel port but not having a square socket and that socket being there since 1995 has complicated things). IMO, the best place to install the aftermarket gauge's sender in the factory location.
Regards,
-g
Q:
http://goo.gl/csaet4
S4gunn is offline
post #14 of 19 (permalink) Old 04-11-2011, 03:45 PM
slick59's Avatar
The sensor you have circled is the sender for the gauge only. It can be disconnected and not affect anything but the gauge.
I can explain it to you, but I can't understand it for you
Tim
1994 Cougar 3.8L Supercharged
1990 Tbird Supercoupe
slick59 is offline
post #15 of 19 (permalink) Old 04-11-2011, 05:24 PM
Minor addendum: It will also affect the "Check Gauges" light, so a resistor in its place may be better. See if it lights up with the connector pulled first, though - even at 50 cents, that's still 50 cents out of your budget.
RalphP is offline
post #16 of 19 (permalink) Old 04-11-2011, 06:59 PM
slick59's Avatar
It won't cost anything to pull the bulb out
Tim
slick59 is offline
post #17 of 19 (permalink) Old 04-11-2011, 08:44 PM
S4gunn's Avatar
Instrumentation along with safety equipment (ex: brakes and tires) are "free".
Plus, in qty 100, resistors are 2c from jameco.com AND they allow for local pickup.
-g
S4gunn is offline
post #18 of 19 (permalink) Old 04-11-2011, 09:36 PM
-g
True. But if it DOESN'T light up when it's unplugged, you're good to go with it unplugged.
OTOH - if instrumentation is "free", why not grab an all-threads galvanized nipple and a "Tee" and some nylon tape?
RalphP is offline
post #19 of 19 (permalink) Old 04-11-2011, 11:54 PM
S4gunn's Avatar
Simple: We're cheap and we could care less about the factory gauge
-g
S4gunn is offline
