Car wont start - TCCoA Forums
post #1 of 6 (permalink) Old 05-04-2007, 05:29 PM Thread Starter
Birdman232's Avatar
Car wont start
97, 3.8L
The ignition lock cyl broke and now i replaced it and the car wont start. With the key out the dash lights and AC/heat will still run. I cut the wires for the Cruise control,and horn/airbags when i put a different steering wheel in. There is a pink/black wire that has a little C shaped plastic piece that sits under the lock and taht is in place other than that I havent messed with the wiring...Now the car just sits there and drains the battery....I dont understand how to fix this or what to look for. All fuses are good(checked under dash and in the engine bay. Any advice would be appreciated.
Birdman232 is offline
post #2 of 6 (permalink) Old 05-04-2007, 05:41 PM
Good Grief Charlie Brown.
Hollywood Ed is offline
post #3 of 6 (permalink) Old 05-04-2007, 06:05 PM Thread Starter
Birdman232's Avatar
I appreciate your help..../end sarcasm.
Its probably hard to read, if that what you mean..but i think anyone that reads it can get the clue....
post #4 of 6 (permalink) Old 05-07-2007, 06:46 PM
does the coil on the fender wall ring a bell try bypassing it just get somthing metal and touch the 2 big bolts on there
Destructor90 is offline
post #5 of 6 (permalink) Old 05-07-2007, 11:56 PM
There is no coil on the fender wall. He has a 97 and the solenoid you speak of is mounted to the starter.
In the steering column there is a rod that moves forward and back when you turn the lock cylinder and moves a rod on the ingition switch, and this switch changes the different running modes of the car (i.e. ACC, Off, Start, Run). This rod is probably broken and unfortunately it is a PITA to fix. It's not really a fix but what you can do until you feel spiffy enough to fix the problem is drop the ingition switch and manually control the mode of the car. Under the steering column there is a box with 2 torx screw holding it in place. You may have to remove the steering column trim to access both screws but once you remove the screws, the switch will drop down and you can move the rod on the switch by hand.
post #6 of 6 (permalink) Old 05-08-2007, 09:22 AM
white lincoln's Avatar
LOL!
Sorry, it is rather funny about cutting wires and all. I hope you find the problem.
white lincoln is offline
