Injector replacement interval - TCCoA Forums
post #1 of 11 (permalink) Old 05-06-2007, 10:43 PM Thread Starter
What is the recommended interval to change injectors on the 3.8?
packratt is offline
post #2 of 11 (permalink) Old 05-06-2007, 10:54 PM
white lincoln's Avatar
When they start giving you problems? I looked and could not find anything in the service manual. Maybe someone else might have an idea.
white lincoln is offline
post #3 of 11 (permalink) Old 05-06-2007, 11:06 PM
twin turbo 281's Avatar
there is no interval if you suspect a leaking of cloged injector then have them tested...but most of the time testing or cleaning costs just as much as replacing the stock injectors so you might as well replace them if you suspect a problem
2x95 cougars to the scapper
51 Mack A51T restoration
twin turbo 281 is offline
post #4 of 11 (permalink) Old 05-06-2007, 11:42 PM
Yeah injectors don't have a service interval. They get replaced when they no longer function properly and the problem can't be remedied with a cleaning.
post #5 of 11 (permalink) Old 05-07-2007, 12:02 PM
That was my impression. When they go, replace them. I would start with some (a lot) SeaFoam through the system (gas tank and intake) and see if that helps. Cheaper to buy $7 of SeaFoam than a $60 - $140 injector. Then you have to consider all the other things that may act like an injector going bad...
1) TPS
2) Wires and plugs
3) o2 sensors
4) IAC
5) poor gas
6) etc. etc...
post #6 of 11 (permalink) Old 05-07-2007, 01:53 PM
Here are some injectors for 3.8l's:
http://cgi.ebay.com/ebaymotors/FUEL-...spagenameZWD1V
post #7 of 11 (permalink) Old 05-07-2007, 03:06 PM
PCD
Confirmed V6 Nut
www.fiveomotorsport.com has both new and refurbished injiectors, and you don't have to win an auction to get them.
PCD is offline
post #8 of 11 (permalink) Old 05-07-2007, 03:08 PM
Cool. Na, these are outright buys, no auction. I just saw them when I was looking for some stuff for my 94...
post #9 of 11 (permalink) Old 05-07-2007, 07:57 PM Thread Starter
Before I buy them I'm going to break the scanner out and run the diagnostics on the car.
I know my 6.5TD recommends replacement of injectors at 100,000 miles and I couldn't find anything in Mitchell on the 3.8 replacement interval.
With 186000+ I think it is getting time to replace them.
packratt is offline
post #10 of 11 (permalink) Old 05-07-2007, 11:40 PM
At 185k mine are still working perfectly. Don't waste your money if you don't need to buy them. An injector balance test or flow test will tell you whether or not to replace them.
post #11 of 11 (permalink) Old 05-08-2007, 09:27 AM
NS! I would go for some o2's before the injectors! Have you replaced the o2's since 100k packratt? It sure solved a lot of my problems; but then again, its still a 3.8l.
