Electronic Shift Control Sensor - TCCoA Forums
post #1 of 8 (permalink) Old 11-18-2008, 08:39 PM Thread Starter
MaddMartigan's Avatar
Can you give me a part number and price on a electronic shift control sensor for a 2002 Ford Explorer v8 Eddie Bauer edition?
1992 Ford Thunderbird SC
-10.5:1 Compression Ratio
Trick Flow Stage 1 cam
Trick Flow Street Heat Intake
Mac 1 5/8 long tube headers
FRPP 42# injectors
3.27 gears
Custom aluminum driveshaft
M5R2
Burned Chip for SN95 T4M0 ECM
OMGHI2U
MaddMartigan is online now
post #2 of 8 (permalink) Old 11-18-2008, 10:00 PM
i like your age
post #3 of 8 (permalink) Old 11-20-2008, 10:57 AM
Johnny Bling Bling
93 lx's Avatar
can you give me a better description? even the tech was confused!
2009 Ford Flex Limited AWD
93 lx is offline
post #4 of 8 (permalink) Old 11-20-2008, 11:53 AM Thread Starter
OK.
Here's the situation: I have the dreaded "Check Advtrac" message in the message center. Based on the research I have done, the recommended solution was to replace the Electronic Shift Control Sensor which is a sensor under the dash. The symptoms of this problem are that we can select any 4x4 mode, Advantrac is disabled and the 4x4 High and Low light flashes during driving occasionally.
We're stuck in two wheel drive until I can fix it. Is that enough of a description to help out?
Supposedly this is a picture of it:
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #5 of 8 (permalink) Old 11-21-2008, 10:33 AM
Johnny Bling Bling
93 lx's Avatar
i have the part in stock, and can ship it out today. part would cost you $218.09 plus UPS.
93 lx is offline
post #6 of 8 (permalink) Old 11-21-2008, 12:44 PM Thread Starter
Does your tech think that is the solution to the problem based on what I said?
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #7 of 8 (permalink) Old 11-21-2008, 12:49 PM
Johnny Bling Bling
93 lx's Avatar
they are somehat popular, and there is a reason we keep it in stock. can i guarantee that's the problem....not without a proper diag. have you brought it toa dealership yet?
93 lx is offline
post #8 of 8 (permalink) Old 11-21-2008, 01:37 PM Thread Starter
Nah, I haven't brought it to a dealership since the cost isn't justifiable. The vehicle is basically 7 years old and paid off. If it's going to cost more than a of hundred dollars to fix then it's not really worth messing with since that's probably just the first of many things to start happening based on what I'm reading of other people's experience. If I can fix it myself and keep it running for another year or so then I will do that.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
