Lock cover - TCCoA Forums
post #1 of 6 (permalink) Old 11-21-2008, 05:26 PM Thread Starter
Geek w/Gearhead Complex
Fubarian's Avatar
Lock cover
need a lock cover for a 96 mark 8. Also, is there a motor device thingy that controls the IMRCs that you can replace/buy?
96 Mark VIII [email protected] :: 03 radiator/fan - j-modded trans - BBK UD pulley kit - dual gauge pod - 28,000 B&M transcooler (w/ AN fits) - 3.73 locker (with speedo gear) - 180' thermo - 8.5mm wires - colder plugs
soon to install : "fixed" heads and a damn tune. Project snaked8 continues...
Fubarian is offline
post #2 of 6 (permalink) Old 12-02-2008, 08:10 AM Thread Starter
Fubarian's Avatar
anything? anyone?
Fubarian is offline
post #3 of 6 (permalink) Old 12-02-2008, 08:43 AM
Can't help with the lock cover.
For the IMRC's are you looking to upgrade to something different, or repair what is on there.
I've never seen the Gen I vacuum motors sold separately, and the Gen II's use a PCM controlled motor.
69 F100 LWB w/460 Engine
post #4 of 6 (permalink) Old 12-03-2008, 09:28 AM Thread Starter
Fubarian's Avatar
sure, pick one. I have a feeling its not opening properly (haven't torn into it yet -- still got cams/heads that need to go on the car)
Fubarian is offline
post #5 of 6 (permalink) Old 12-03-2008, 09:47 AM
I'll look around the house. I think I have a pair of Gen I IMRC's that I'm not using.
Most likely they are just all gummed up and not operating properly. If you have a one of those Mity-Vac brake bleeders thingies, you can pull a vacuum on the lines going to the pots and see if each one of them is holding vacuum. That will at least eliminate a busted diaphragm. It won’t tell you if the butterflies are opening or not, but at least that will rule out one thing. Then test to see if the IRMC solenoid is operating by pulling vacuum on the inlet side and applying the correct voltage signal to the solenoid (without the EVTM in front of me, I don’t remember if it is a straight 12v solenoid or not) and see if you have vacuum on the outlet side.
I think those things should be able to be tested without having to remove too much stuff.
Just some thoughts on some things you can check without having to pull the intake. But I’ll still bet they are nasty and cruddy.
Good luck!!
post #6 of 6 (permalink) Old 12-04-2008, 07:32 AM
joshbea6's Avatar
You can always get it puton the engine diagnostic computer and it should be able to tell you if they are opening or not. Of course this would require you to actually take the Mark to the Stealership instead of redneck, backyard, guestimating...
joshbea6 is offline
