Hyd. slave bracket - TCCoA Forums
post #1 of 5 (permalink) Old 01-04-2010, 12:45 PM Thread Starter
Hyd. slave bracket
I need a hydraulic slave cylinder bracket (E4TZ-7A544A) for a 89 F-150. I am putting an upgrade on my '68 F-100 using a Clevor engine that didn't have the stud boss in the block. I could also use the master, slave & line if you can get me some numbers/prices.
Lee
L. Thomas
97 Tbird Sport
99 J-Mod Tranny
PBR calipers
270K miles and still flying, just not daily!
Generalee is offline
post #2 of 5 (permalink) Old 01-04-2010, 01:25 PM
A clevor? I haven't seen one of those built in a LOOOOOOONG time. Just out of curiousity, why did you not just go with a set of aftermarket windsor heads?
MadMikeyL is online now
post #3 of 5 (permalink) Old 01-04-2010, 02:36 PM
really?
I see them from time to time on corral.net
post #4 of 5 (permalink) Old 01-04-2010, 02:43 PM
Well I haven't been looking for one, and usually the only time I go on corral.net is to look for something in the classifieds, but the last time I just stumbled across one was back in 02 or 03.
post #5 of 5 (permalink) Old 01-04-2010, 06:59 PM Thread Starter
I was just out of Engineering school and was looking for an efficent powerplant-one with a good rod to stroke ratio using factory parts. The clincher was when I found a pair of Australian Cleveland 2V heads with the closed chambers. The ole truck had a 351C when I got it but knew it would be expensive to build.
L. Thomas
97 Tbird Sport
99 J-Mod Tranny
PBR calipers
