Ford remote start/alarm (gold unit) - TCCoA Forums
post #1 of 6 (permalink) Old 01-15-2010, 11:31 AM Thread Starter
RidinOnAir's Avatar
I just bought one, but I need the wiring harnesses for it. Are you able to get them? If so, please let me know. There are 3. Thanks
RidinOnAir is offline
post #2 of 6 (permalink) Old 01-29-2010, 11:42 AM Thread Starter
RidinOnAir's Avatar
post #3 of 6 (permalink) Old 01-29-2010, 03:10 PM
Just a FYI , Not sure that we still have a TCCoA parts vendor
post #4 of 6 (permalink) Old 01-29-2010, 04:04 PM Thread Starter
RidinOnAir's Avatar
haha..ok. That would make sense. Can't find just this part ANYWHERE online. Stealership wants 150 just for this harness (the brain, harnesses and kit is online for only 245). Typical
post #5 of 6 (permalink) Old 01-29-2010, 05:25 PM
decipha's Avatar
i don't know what kind of harness your refering to might as well just use your alarm pins and wire them accordingly, every alarm i've ever installed i've never used a prefabed harness I just ran the alarm wires to what I needed. Heres the wiring for your 94
Constant 12V+ Black/Orange Ignition Switch Harness
Starter Red/Blue Ignition Switch Harness
Ignition Red/Green Ignition Switch Harness
Ignition 2 Gray/Yellow Ignition Switch Harness
Accessory Black/Green Ignition Switch Harness and Gray/Yellow for Heater
Tach Gray/Orange Ignition Module, 12 Pin Connector
Neutral Safety Wire Not Grounding OEM Switch opens Starter Circuit
Brake Switch Black/Pink Brake Switch
Trunk Release Purple/Yellow (+) Driver's Kick Panel or at Switch in Console
Trunk Pin Brown/White (-) Pin Switch with Factory Alarm
Parking Lights Brown Light Switch
Head Lamp Red/Yellow (+) Light Switch
Factory Disarm Dark Green/Purple (-) Driver's Kick Panel
Door Trigger Black/Light Blue Under Dash Light
Door Lock Pink/Yellow Driver's Kick Reverse Polarity use Passenger's Switch to test
Door Unlock Pink/Light Green W/Keyless Negative Trigger
Horn Wire Yellow/Light Green (-) Steering Column
Windows Up LF=Yellow, RF=Tan/Light Blue at the p/w switch
Windows Down LF=Yellow, RF=White/Black
supercoupin'
www.EFIDynoTuning.com
decipha is offline
post #6 of 6 (permalink) Old 01-29-2010, 05:27 PM Thread Starter
RidinOnAir's Avatar
Thanks, its not for my 94, its for my 07 f150. But thanks, didn't even think about doing that.
