having no luck for knuckles - TCCoA Forums
post #1 of 6 (permalink) Old 01-15-2013, 05:56 AM Thread Starter
i have been to several salvage yards and parts stores had no luck. the salvage yards i have seen the drum type of knuckles in the rear i am looking for the type for the calipers. any help i will be glad for the help in getting them thank you
95mercxr7 is offline
post #2 of 6 (permalink) Old 01-15-2013, 07:12 AM
paintme205's Avatar
I got a set. 65 shipped to your door. Let me know if your interested.
paintme205 is offline
post #3 of 6 (permalink) Old 01-15-2013, 09:10 AM
FordPartsCounter's Avatar
Send a message via AIM to FordPartsCounter
Hi,
Those knuckles are outrages.Ford has 2 RH and 4 LH left in there stock.Dont pass out or laugh to hard when I tell you these prices.
LH Knuckle $342.79 (retail $519.38)
RH Knuckle $279.84 (retail $424.00)
Jason
Crossroads Ford of Indian Trail
Main line 704-926-4486
Cell Phone 704-254-5834
FordPartsCounter is offline
post #4 of 6 (permalink) Old 01-15-2013, 12:08 PM
Just so you know, you can re-use the drum knuckles on a rear disc swap. There are 2 ears cast into the knuckle where the caliper bracket will bolt. On the disc brake knuckles, these holes are already drilled, but if you are doing a conversion, all you have to do is remove all the drum brake components and backing plate, drill out those 2 holes, and bolt your disc brake parts on to your existing knuckle.
post #5 of 6 (permalink) Old 01-16-2013, 12:56 AM
dDUBb's Avatar
Originally Posted by FordPartsCounter View Post
Hi,
Jason
What about the Kit car IRS knuckle set ?
FRPP part number M-5970-A
dDUBb is offline
post #6 of 6 (permalink) Old 01-16-2013, 07:54 AM
The M-5970-A is $399.95 (Retail $475.00).
