4r70w mod - TCCoA Forums
post #1 of 6 (permalink) Old 05-12-2007, 09:32 PM Thread Starter
4r70w mod
what benifit would the tranny in my 96 bird see if i were to do the external tailshaft lube mod? is there a link for this ?
i mite not have that worded rite butt im sure the tranny guys will understand
1990 ford f150 5.0
1989 cougar xr-7 5spd 5.0 --249hp/[email protected]
1989 mustang gt [email protected]
1984 tbird 5.0 auto
1999 chevy tracker...wtf!!!!!
joker77_2005 is offline
post #2 of 6 (permalink) Old 05-12-2007, 10:19 PM
With 4.10 gears, the forced lube mod is a good idea with the revs the driveshaft sees.
Bangster is offline
post #3 of 6 (permalink) Old 05-12-2007, 10:28 PM
The Great Obucina's Avatar
there is an entire section in the thesis devoted to the purpose and benefit of the tailshaft lube line.
"Booyah". Stu Scott.
The Great Obucina is offline
post #4 of 6 (permalink) Old 03-11-2016, 01:51 AM
Cougar Pilot
BlackCat94's Avatar
I can't find it, looked pretty hard over the last couple days!
TCCoA, there's no better way.
BlackCat94 - The Revolution.
BlackCat94 is offline
post #5 of 6 (permalink) Old 03-11-2016, 04:37 PM
Rayo's Avatar
It's on Page 12 of the article..
Click Here-->> Extension Housing Modification
1991 Ford Thunderbird Sport
Rayo is offline
post #6 of 6 (permalink) Old 03-23-2016, 10:08 AM
Cougar Pilot
BlackCat94's Avatar
There's doesn't seem to be such a thing as a .050" drill bit.
A #55 is .052"
