4R70W ? Engine size differences? - TCCoA Forums
post #1 of 21 (permalink) Old 06-02-2007, 03:58 PM Thread Starter
Hey, guys. I did a search but couldn't find a clear-cut answer. I'm junkyard hunting for a used transmission from a 99+ Ford, Lincoln or Mercury that uses the 4R70W. I was just curious, if I found a trans from a 6-cylinder Mustang, would that still swap in relatively easy into my 95 4.6 'Bird, or should I just be looking for 4R70W's that are bolted up to 4.6's? Thanks so much!
Robert
neptunes010 is offline
post #2 of 21 (permalink) Old 06-02-2007, 04:12 PM
ur gonna need a 4r70w that has a 3 bolt starter on the pass side
1990 ford f150 5.0
1989 cougar xr-7 5spd 5.0 --249hp/[email protected]
1989 mustang gt [email protected]
1984 tbird 5.0 auto
1999 chevy tracker...wtf!!!!!
joker77_2005 is offline
post #3 of 21 (permalink) Old 06-02-2007, 04:35 PM
3.8's use a different bellhousing bolt pattern, so the mustang one wont work
post #4 of 21 (permalink) Old 06-02-2007, 04:42 PM Thread Starter
So 4.6 something it is? Thanks again!
post #5 of 21 (permalink) Old 12-08-2007, 05:50 PM
Is the valve body in the 3.8 and the 4.6 the same?
Bakalo420 is offline
post #6 of 21 (permalink) Old 12-08-2007, 09:13 PM
It will work. Wiring issues are the biggest hurdle. If you are looking for a trans that'll just go in you won't find one. Anything decent will require changes.
post #7 of 21 (permalink) Old 12-08-2007, 09:24 PM
i got a 99 mustang v6 valve body from a guy at the local junkyard for free. I was wondering if this a better unit than comes in my 97 tbird 4.6? If so how do i go about installing it?
post #8 of 21 (permalink) Old 12-09-2007, 09:25 AM
i have searched and searched still cant find an answer? if someone can help it would be appreciated. I plan on changing my trans fluid today and want to swap them while I am under there if its worth it? thanks
post #9 of 21 (permalink) Old 12-09-2007, 11:14 PM
It will be marginally better. Worth changing on a stock trans...I wouldn't bother.
post #10 of 21 (permalink) Old 12-10-2007, 09:06 AM
Darrin's Avatar
Actually, there are some significant upgrades in that 99 VB over the one in a 97 bird and if you don't want it, or think it isn't worth installing then I will take it.
Darrin
Darrin is offline
post #11 of 21 (permalink) Old 12-10-2007, 12:12 PM
That is why I got it. Just wanted to make sure it would work since it was from a
v6. Doing the jmod today and throwing it in. Darin, If you need some older valve bodys the junk yard i go to has around 10 thunderbirds I would pull them off for you and we could work something out. I could probaly get my hands on more than that. Mostly 94-95 some 96-98.
Thanks for the info
post #12 of 21 (permalink) Old 12-10-2007, 02:09 PM
For a better built transmission that valvebody will be great. On a stock trans with a roller clutch it will just break faster. You won't see any gain, you'll just get broken parts.
post #13 of 21 (permalink) Old 12-10-2007, 02:42 PM
dDUBb's Avatar
Thanks for the info
Those 94/95 arent good for anything at all, just scrap metal.
dDUBb is offline
post #14 of 21 (permalink) Old 12-10-2007, 04:09 PM
Darrin's Avatar
Just for the record, the improvements in the newer valve body doesn't have squat to do with the application of the intermediate clutch or 2nd gear except for to make sure that the direct clutch is released on that stupid 4-2 downshift. As a matter of fact, all the changes have to do with improving pretty much every other aspect than the 1-2 shift or application of the intermediate clutch in any way that would cause it to come apart.
However you look at it, that is a better valve body for these transmissions than the prior versions. Which is kind of why Jerry said to use those instead of the older ones.
Darrin
Darrin is offline
post #15 of 21 (permalink) Old 12-10-2007, 04:13 PM
Darrin's Avatar
But I will agree that you do need to be careful on those older transmissions that have a roller clutch for the intermediate one way. You don't want to go overboard on the mods because you will break it.
That much is definitely true. The valve body itself won't cause it at all where over modding it will.
Darrin
Darrin is offline
post #16 of 21 (permalink) Old 12-10-2007, 05:52 PM
Would jmoding the valve body to <300hp, changing the 1-2 and 2-3 accumulator hurt my stock tanny?
post #17 of 21 (permalink) Old 12-10-2007, 06:08 PM
The important thing is to watch out for hole #6 unless you have a diode with a spiral retainer on it don't mess with that hole.
post #18 of 21 (permalink) Old 12-10-2007, 07:37 PM
Darrin's Avatar
In all honesty, that completely depends on the transmission. I have seen some of those older ones live through crap that I never would have suspected and others die ugly deaths over things that I also never would have suspected. I have seen some 3.8 cars toast that roller one way clutch on cars where I know they were not really abused and seen some in 4.6 cars that I know were beat the hell out of that were ok.
Actually, the spiral lock for the one way clutch is mostly RPM handling ability and you just can't safely hit those RPM's on a stock 94 or 95 engine anyway. So I wouldn't worry too much about that. You will run into bigger trouble first. LOL
If you are doing a valve body modification yourself then I would follow Jerry's advice on what to do with the holes in the plates and you can find all that info here
http://www.tccoa.com/articles/tranny...n/page13.shtml
and here
http://www.tccoa.com/articles/tranny...n/page14.shtml
He was very kind enough to provide all of us with the best writeup that has ever been for these transmissions and the most accurate and complete info on what those that want to do these mods themselves should do.
Darrin
Darrin is offline
post #19 of 21 (permalink) Old 12-10-2007, 07:44 PM
Darrin's Avatar
Just wondering why you would say that with all of the other improvements that were made to that 99 valve body?
Darrin
Darrin is offline
post #20 of 21 (permalink) Old 12-10-2007, 09:48 PM
Thanks for the info and the help! I plan on picking up the parts tommorrow. Where is the cheapest place to get the accumulators? Ford dealership? Thanks again
post #21 of 21 (permalink) Old 12-10-2007, 11:42 PM
TCCoA Founder
Sir William's Avatar
Darrin, Alan didn't say it wasn't a better valve body. He said that swapping it isn't worth the hassle if that's all you're going to do. Now if you're going to do more to the trans, then sure. But that's not what was said.
Now, before crap goes downhill....which appears to happen too often when you're both in a thread....let it go. I think the appropriate questions have been answered. If he has more questions, he can start a new thread.
.....geez.......
God Bless and Fly Low!
Sir William
TCCoA Founder
97 Thunderbird LX - Smoothed
99 Expedition Eddie Bauer
04 Grand Cherokee Overland
Sir William is offline
