4R70W Valvebody on AODE - TCCoA Forums
post #1 of 10 (permalink) Old 06-17-2007, 11:26 AM Thread Starter
I`m planning to upgrade my 94 AODE with 96-97 4R70W valvebody. What parts do i need to install the VB? Some kind of dowel kit? Will the old wire harness fit?
Melbac is offline
post #2 of 10 (permalink) Old 06-17-2007, 11:42 AM
Awaiting E-Mail Confirmation
tinman_72's Avatar
'94 Birds and Cougars came with the 4R70W from the factory so it will fit right in.
tinman_72 is offline
post #3 of 10 (permalink) Old 06-17-2007, 11:44 AM
Yes you need the adapter pins to do this. Make sure to use your 94 tcc solenoid. Might want to replace the accumulators while you are in there.
post #4 of 10 (permalink) Old 06-17-2007, 12:06 PM
His 94 Mustang would have an AODE
Bangster is offline
post #5 of 10 (permalink) Old 06-17-2007, 12:14 PM Thread Starter
Ok, thanks, where can i buy these adapter pins? I have already updated the accumulators..
Melbac is offline
post #6 of 10 (permalink) Old 06-17-2007, 12:18 PM
F6AZ-7K720-A should be two of them. You also want the gasket for the newer VB
Bangster is offline
post #7 of 10 (permalink) Old 06-17-2007, 03:20 PM
Might want to swap in a deep dish trans. pan while you've got the original off. It's a cheap enough upgrade.
post #8 of 10 (permalink) Old 06-17-2007, 03:29 PM
I think he clarified that originally.
post #9 of 10 (permalink) Old 06-17-2007, 05:18 PM
Tinman implied that it was a 94 4R70W, and I just wanted to point out that not everything had a 4R70W that year. Useless information and not helpful to the original poster who indeed posted it is for an AODE. Maybe he has signatures turned off, or figure that any post here would be for an MN12 ::shrug:: You can say he knows that there isn't any difference in 94 AODE and 4R70W, but didn't know that in 96 they changed the dowel pin size along with the VB.
Bangster is offline
post #10 of 10 (permalink) Old 06-17-2007, 09:05 PM
tinman_72's Avatar
I generally skip reading signatures. When he wrote "my '94 AODE" I assumed he meant in a '94 MN12 since he didn't mention a Mustang under his avatar. I figured that like most newbies he had misidentified his transmission.
He got the information he needed so it is no big deal.
